ARCHIVED: [DEAD ROM] ThundeROM V1.8.3 4/5/2011
Status
Not open for further replies.
Not a huge fan of 1.8. The home button does not function and I preferred having the power button allowing me to go into airplane mode.
I just flashed 1.7 but I was not pleased to find that the keyboard has changed from 1.6! Anyway I can revert back to the gingerbread keyboard fellas?
Download the Gingerbread Keyboard app in the market. Works like a charm.
Yep, just get the Gingerbread keyboard from the market. Also, there are links somewhere in this thread to files you can download for the buttons. May be on the first page. Personally I like the setup of the buttons as is but hey, it's all about customizing the way YOU want it. I'm lovin' this ROM! :D. Hope that helps!
Can anyone tell me why with a 8 gig sd card titanium backup says
SD Card (a2sd): 166mb
I have a 1gig ext3 partition on my sd but specifically didn't tell android to mount it. Where is this 166 number coming from?
I had no luck on TB website
Thanks!
if i have 1.7, do i still need to wipe my data cache? just sucks cause then i have to reinstall all my apps and data
I wiped cache and dalvik cache, didn't wipe data, and upgrading from 1.7 to 1.8 worked fine.
PowerOn Sounds
Running 1.8.
I noticed that the /System/Sounds/PowerOn/ directory was gone. I occasionally like to add a little boot up music to mine(I added a bit of the Firefly Theme awhile back) and I decided to add it again. I noticed the folder and file were gone. Is there a way to get it back? I tried manually adding the folder and made a PowerOn.mp3 but got nothing. Apologies if this was asked already. I looked through the thread, but at 100+ pages...I might have missed it. :)
Ok, I updated to ZVD & flashed TR 1.8 (xionia cw). Now I am unable to use my wifi settings to connect to an access point. It's pretty much disabled and below the Wifi, it says error. Everything else works fine.
***Fixed***
Wiped davlik & re-flashed rom....back to normal.
Yeah its sweet and better then Sprint, but how do I change the ThudeRom text on the notifcations drop down?
I could be wrong, but I believe that you can use Root Explorer (it costs money, but it's the easiest method) to open /system/build.prop with a text editor, and somewhere in there, you should see an alpha value about the carrier that says "ThundeROM". You should be able to replace it with anything and save.
Reactions: Part_Human
or the free method
open cmd or what ever terminal client you happen to use on your COMPUTER, i'm sure there's a way to do it in android but i don't know it. once in cmd cd in to your adb folder, as a side note, it would be a good idea to go ahead and open the actual folder up too as you'll have to be in this folder to get the file that you pull
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>cd c:\android/platform-tools
c:\Android\platform-tools>adb pull /system/build.prop
178 KB/s (5128 bytes in 0.028s)
see free, now remember when i said to go ahead and open your adb folder, that's where your "build.prop" file will be. Open it up in whatever text editor you want, you do not need special permissions, edit what you want and save right back to your original file, or make your original a back up by changing it's extension and save the modified one as build.prop, but make sure it's saved to the same folder as adb, in my case, c:\android\platform-tools\. roads fork here
if
you want to leave the unedited build.prop on your phone as a back up(which is what i did);
C:\Windows\system32>cd C:/android/platform-tools
C:\Android\platform-tools>adb push build.prop /sdcard/build.prop
500 KB/s (5128 bytes in 0.010s)
C:\Android\platform-tools>adb shell
# mount -o remount,rw -t yaffs2 /system /system
# mv /system/build.prop /system/build.prop.bak
# mv /sdcard/build.prop /system/build.prop
# reboot
reboot
I rebooted but i'm not entirely sure that you have to.
else
now if you do not feel the need to/or don't want to leave the back up on the phone;
# reboot
reboot
again not sure if you absolutely have to reboot, but thats what i did
Irony is that the tool I use to check for virus infestations on my Android actually identified one of the copies of z4root as having a virus... and I've only ever downloaded that from either here or xda...
*sigh*
Edit: also, if software piracy were you only reason for rooting, you didn't need to root to do that on Android...
*sigh*
RATC is considered a virus by most virus software companies. RATC is the method z4 uses. If you want to be sure, you can download z4 root right from ryan (the developer) but i'd guess the results would be the same.
Status
Greenfid28
