ARCHIVED: [DEAD ROM] ThundeROM V1.8.3 4/5/2011
Status
Not open for further replies.
Question how do I get sprint id into this rom? Looking to get the ESPN ID pack, but can't seem to get it on this rom. Please help. Thanks.
Just wanted to say thanks again for this ROM. I noticed the new update and got jittery lol. I do have a question though, using setcpu, what should the min value be around?
I saw someone else recommended it be around 245 so the unlock goes smoother and less glitchy. I can vouch for this. I had it at the lowest (122 i think) and it was pretty jumpy during the unlock, but setting it one notch higher fixed it perfectly. I also have a profile set to limit it to 320ish when the screen is off, just in case there's any rogue apps that happen to be running in the background..
Reactions: jtcady
You should be able to flash it without rebooting.I can't promise that it won't give you problems but it didn't to me when i did it.
Thanks. I flashed 1.6 and then deluxe build prop in the same recovery session, and the phone booted up fine. 1.6 looks great! One thing I noticed is that my Build number still says 'ThundeROM-V1.5S'. I'm not sure if I had held off on flashing the deluxe buildprop and just rebooted after flashing 1.6 if it would have listed my Build number as 'ThundeROM-V1.6' or not, but either ThundeROM 1.6 doesn't have an updated Build number or flashing deluxe buildprop drops the Build number back down to 1.5. I definitely have 1.6, though - very nice translucent notification tray!
Great ROM.
Experiencing some pretty major keyboard lag that I didn't get in 1.5. Rebooting solves the problem for a little while. The lag holds across the 4 keyboards I have installed.
Narrowed down the keyboard lag to when using the built in wireless hotspot. Someone want to confirm this?
Tried that, no luck. I've also tried flashing the JIT only buildprop, and even manually cleaning out the thumbnails stored in the DCIM folder on the SD. Nothing. Looking through aLogcat, I am seeing the following message repeated every time I go into thumbnail view, seems connected:
D/skia (2255): -- SkImageDecoder::Factory returned null
Any ideas from that?
Thanks.
PS - And no, aside from loading Thunderom1.6 onto it to flash, haven't done anything with the SD since 1.5. TR1.6 was loaded by enabling USB on the phone and copying, never even removed the SD from the phone at all.
Hmm not sure ill check somethings out.
Stock min is 245,we have set it to 122min.
I haven't had this issue,are you getting this with even the stock keyboards that we included?
I've been looking into how to be able to add espn pack to ThundeROM,as soon as something is figured out it will be up for download.
Some might like 245,we in testing have not had any issues with it running the way we had it set. It's more of set it to what works best for you and your phone.Onething that we did do was remove the window animations that was causing a slight lag on unlock.Either way works.lol. I agree tho i run a profile for screen off and have it set to scale from 122min /320max.
Great ROM.
Thats my fault i must of forgot to edit that buld.prop somehow.As you stated you are running 1.6 cause the notification menu. Sorry will make sure to fix.
I wish I did have a screenshot of the fonts before just to make sure I'm not crazy! ;-)
Unless ksmith changed them up i don't think so,but i could be crazy.lol Ill see if i have any older screenshots.
Reactions: fathom614
Thanks guys, I had formatted the sd card in my hero before removing and putting it in my optimus - I'm wondering if that was one of the issues as well. The rebooting happened before I could install anything after a full wipe and fresh flash of 1.6.
I'll try formatting the card and only copying the necessary data back to reflash the rom. Thanks for the suggestions!
So glad I don't have a winmo...
I formatted the card in recovery, but still the rebooting continued. So then I swapped it out (was using a class 6 4gbcard) with a 2 gb i had. Same issue, doesn't even make it through setup before rebooting (after wiping data, cache, and dalvik and flashing the rom again).
I'm going to try another rom and see what happens... Might be a trip to the sprint store if it continues.
I can see a little lag when i start the app and shortly after i haven't actually connected and pulled on it so i could see lag happening tho if your connected to tethering.I don't know if there's much we can do for that.Ill surely check it out tho.
I was going to say try running the max 600 boot from the second post but then i remembered said the reboot problem happened before. I'd alway give another rom a try to see but if it continues i would make sure to get it changed out before it becames worse,unusable.
No biggie, it's not a huge deal. The lag definitely gets worse when data is being pulled. Tempted to flash 1.5 just to make sure it wasn't there as well.
Hey Beezy, When I installed the Sprint Football Live it responds with "Error- Sprint Football live is only available for Sprint and Nextel users"
Is anyone else having this issue? I downloaded them directly from this site.
Thanks for tracking it down. Ill probaly being jumpping back to 1.5 just to double check but if you get to it before me let me know if it does/doesn't.
hmm ill check that out might have to update the app and post a new zip for everyone to download that wants it. Ill get back to you with that.
Thanks.
Attached is the sprint nfl football apk not sure if it's newer or not.Also attached is fix-sprint-apps.zip,flash the zip install the app after reboot and everything should be working. :D
Well guess we know what one of the fixes will be for the new build.
177 downloads and counting for the day.
That was going to be my next test, however, I flashed nROM and had the same issue after I booted and installed setCPU and overclocked the kernel... appears I have a very weak link somewhere in hardware (which is maximized when overclocked). I'll try taking it into a store and see what they'll do for me, as it's doing it on stock as well.
Eh I uninstalled SetCPU.. seemed to drain battery more and this ROM is already fast enough
Status
Vector
