So now the kernel settings (748 max and 122 min) are active? Sorry for the nooby question, just wanted to make sure I didnt have to change anything after uninstalling.
interesting issue i came across.
on v1.6 put my phone on to charge. (sometimes i will power off phone while its on charge). powered down. plugged in. and of course goes to to the LG sign..(and normally goes to the charging battery icon..)however since installing v1.6 it just powers back up when plugged in. even if while plugged in and power down (reg. power down, or using quick boot) it will just reboot it self. ignoring "power down".
tried a few things even wiping completely and still same thing..(even took battery out and back in)...(was just checking everything)..went back to v1.5 etc and no issue. (powers down while plugged in or after plugged in and stays off).
im guessing that with the deletion of "sprint boot - animation" the power off - charging battery image was also deleted?
really no biggie just curious, if having no sprint boot image causes this, ill still go to v1.6 just something i noticed.
To beezy, any luck with that error message I was seeing with thumbnails in the Gallery App? Is there any method to reinstall just that app (since it seems to be one included on the phone) to see if that fixes it?
No one else has seen an issue with your thumbnails disappearing in the Gallery App?
Lmfao,good catch that completely slipped right by me,I don't think i have ever left one of my phones off so i didn't even think to check that. It's because the removal of all the junk in the boot.img.I thinkn i know how to fix it very easy.Thanks for letting us know ill get this addressed asap.
This is a feature as far as I am concerned. My battery dies sometimes and being able to just plug it in and it will boot up (like my old blackberry) is awesome.
Just checked my phone and thumbnails are working just fine, and since you never mentioned it anywhere that I see, have you tried re-flashing v1.6?
If not it couldn't hurt to try.
lmao although a funny post, we're gonna be fixing that soon. The phone charges when off just fine, we removed the images it displays while charging when turned off. I guess because neither of us EVER turn off our phones, we never noticed
Or we could just pull the move of a famous fruit logo phone making company, call it a feature, and be done with it. One more special feature of this release we forgot to mention ... you actually have to hold your phone a certain way for the ROM to work. I'll make sure i add that to the first post! kidding!! I actually don't mind the iphone (it is a great device), just really dislike the company that makes it.
Aside from that, is there any way to easily see now what is enabled in the kernel? The 1.5 version showed this to you via a little "j" or "s" after the ROM name if I recall correctly. That doesn't seem to show up anymore.
Likewise, is it okay to still use the buildprop files provided in the other thread in order to flash between those options? Anything change between 1.5 and 1.6 that would cause those to need an update?
Thanks.
Just updated to version 1.6 and have been real impressed with the update. Since I came from Stock ROM I had to reinstall the Sprint Apps. One of the apps that I use is NASCAR Sprint Cup Mobile. I installed it from the sprint-apps zip file, and it installs just fine. But when I go run the app, I get an error. "NASCAR is only available for Sprint and Nextel Users", does anyone know how to get this to work?
Thanks.
Chris
