ARCHIVED: [DEAD ROM] ThundeROM V1.8.3 4/5/2011
Status
Not open for further replies.
Happened to me to, got rid of that "hotspot widget" rebooted, all is good... right now :cool:
If you still have any widget after flashing the ROM (for the first time) then you're not doing a full wipe. A full wipe will get rid of everything including market apps, non markets apps, widgets, settings, contacts, on and on. The Factory/data wipe is what does this.
Thought i might need to re-download after total wipe... did and then had prob w/ wifi. got rid of the widget and bam all is good
Change of subject, why cant i get into the "sprint apps store" in the sprint zone? thought i might be able to re-download sprint TV.
Sprint TV isn't in the app store, none of their proprietary apps are in there unfortunately :\ . And ... i dunno .... I can get in.
Beezy has all the Sprint apps gathered up and will be making them available soon though :cool:
Reactions: Kalums
SAWEEEET... WTG you guys are awesome, i love this ROM it rocks and it runs noticably faster even w\o OC :D
I followed your instructions and at first it was giving me the same error but now the wifi is working. The only thing that changed was that I was charging my phone. I am on a low battery, do you think it shuts off wifi when at a low battery? Is that what "WiFi Radio adjusted for battery" means?
Nope. What that means is they had the wifi radio set to check for connectivity every 15 seconds which is a bit excessive in our opinion so we decided to adjust that which equates to better battery when you have the wifi radio on :) when you consider some people leave wifi on constantly, even when not in wifi range, this translates to really big savings for them.
Bug ?
has anyone else pluged in their head phones yet? I just hooked my phone up via the head phone jack and wifi turned off ( and then came back on) and pandora shut down. did it twice after re-installing pandora.
Bug ?
Just tried this and it works fine for me, I am running v1.2 of ThunderROM.
this is awesome, convinced me more to get this phone. just to get me more hooked, would it be possible for someone to post more pics or videos of the run through of this rom? it'd be greatly appreciated.
Also, are the live wallpapers available? like the N1 one? thanks
Yes, we have live wallpapers :)
Sent from my LG Optimus.S using Tapatalk Pro.
Still love this rom. Haven't seen any issues related to the rom itself. Only related to the android software itself.... Keep it up guys. I especially like the battery level indicator
Those running ThundeROM V1.2, are you able to see Google voice icon in quick contacts? I'm missing it and don't want to flash it again since i spent most of the day customizing it :)
I havnt seen any area that voice is not in so yes so far it all works on 1.2
Quick question. I've noticed that this ROM contains KickBack and SoundBack apps. What do they do? Do they improve anything or can they be removed?
thanks
thanks
leave them.
Talkback.apk & Kickback.apk are connected to Accessibility
You can see this API in use within our Open Source Android screenreader TalkBack. With TalkBack installed, standard Android user interface elements such as ListView produce spoken feedback during user interaction. Applications SoundBack (for producing non-spoken auditory feedback) and KickBack (for producing haptic feedback) generate additional augmentative output and demonstrate how multiple access applications can be active simultaneously.
Status
Erioinajake
