[DEVS ONLY] ics repo
Looked at this closer today. It looks to be a clever hack for backward compatibility. But it relies on _INTERNAL_BINDER_PARCEL_ only being set internally, not globally. For some reason the BoardConfig.mk that I snagged from lupohirp has this set as a global cflag and that's what is causing the issue. So here's the real fix, in my device/lge/thunderc/BoardConfig.mk:
Code:
-COMMON_GLOBAL_CFLAGS += -D_INTERNAL_BINDER_PARCEL_ -DUSE_LGE_ALS_DUMMY
+COMMON_GLOBAL_CFLAGS += -DUSE_LGE_ALS_DUMMY
It worked! But now there's a new error....
Libqcomui is complaining about something
Just FYI - If you sync with CM to begin, then pull in tdm's device and vendor folders, then pull in mikegapinski's webrtc fix and tdm's cm/tools fix, you'll have a working build, remove the terminal and ROM Manager packages. ;)
Code:
mkdir -p ics
cd ics
repo init -u git://github.com/CyanogenMod/android.git -b ics
repo sync
git clone git://github.com/tdm/tdm_device_lge_thunderc.git
mkdir -p device/lge
mv tdm_device_lge_thunderc device/lge/thunderc
git clone git://github.com/tdm/tdm_vendor_lge_thunderc.git
mkdir -p vendor/lge
mv tdm_vendor_lge_thunderc vendor/lge/thunderc
// edit vendor_thunderc.mk to remove the terminal and ROM Managaer packages
// manually add in mikegapinski's webrtc fix
// manually add in tdm's cm/tools fix
. build/envsetup.sh
lunch 5
make bacon
From there, start to bring init.thunderc.rc and init.rc more inline with IHO's, add CdmaSMSDispatcher.java from the triumph as well as tdm's MMS hack, change the apns-conf settings for mcc and mnc and crib in IHO's mms_conf file.
This will give you a working build with offline-charging (still a bit buggy), working MMS, and pretty much everything else except camera/video.
What's really needed atm is a kernel with a working xt_qtaguid module. ;)
How do I use the diffs to use the webtrc and cm tools fixes? i pm'ed you but a generated message said you would be able to reply.
Use the patch utility. It is well documented and there are tons of examples online.
It worked! But now there's a new error.... Click to view quoted image
If you recently synced, you will need to pull/merge the latest android_hardware_qcom_display from CM.
git pull git://github.com/CyanogenMod/android_hardware_qcom_display ics
Then add to the BoardConfig.mk
+COMMON_GLOBAL_CFLAGS += -DQCOM_HARDWARE
Then in the device folder, in the libstagefrighthw folder, disable the Android.mk to Android.mk~ .
Then add this line to pick the correct new cm9 bootanimation in Cm.mk
# Release name
PRODUCT_RELEASE_NAME := OptimusS
+TARGET_BOOTANIMATION_NAME := vertical-320x480
My thunderc-vendor.mk looks like this. I'm trying out the stereo audio fixes from Adfad666.
Code:
KERNEL_MODULES_DIR := /system/lib/modules
TINY_TOOLBOX := true
WITH_WINDOWS_MEDIA := true
PRODUCT_PROPERTY_OVERRIDES += \
    dalvik.vm.dexopt-data-only=1 \
# Audio
PRODUCT_PACKAGES += \
    audio_policy.thunderc \
    audio.primary.thunderc
# Display
    libgenlock \
    libmemalloc \
    liboverlay \
    libQcomUI \
    libtilerenderer \
    libopencorehw \
# QCOM OMX
    libstagefrighthw \
    libOmxCore \
    libmm-omxcore \
    libdivxdrmdecrypt \
    libOmxVdec \
    libOmxVenc
# Misc
    com.android.future.usb.accessory \
    gps.thunderc \
    lights.thunderc \
    hwaddrs \
    lgapversion
    libjni_latinime \
    librs_jni \
    brcm_patchram_plus \
    copybit.thunderc \
    gralloc.thunderc \
    sensors.thunderc \
    bash \
    nano \
    e2fsck \
    flash_image \
    erase_image \
    dump_image \
    thunder_keypad.kcm.bin \
    Provision \
    GoogleSearch \
    LatinIME \
    hcitool \
    QuickSearchBox \
    FileManager \
PRODUCT_COPY_FILES += \
     vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/gps.conf:system/etc/gps.conf \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/permissions/android.hardware.microphone.xml:system/etc/permissions/android.hardware.microphone.xml \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/01_qcomm_omx.cfg:system/etc/01_qcomm_omx.cfg \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/MELFAS_FIRM.bin:system/etc/MELFAS_FIRM.bin \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/wiperconfig.xml:system/etc/wiperconfig.xml \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/loc_parameter.ini:system/etc/loc_parameter.ini \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/init.rc:root/init.rc \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/ueventd.rc:root/ueventd.rc \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/media_profiles.xml:system/etc/media_profiles.xml \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/tweaks.sh:system/etc/tweaks.sh \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/setwifi.sh:system/etc/setwifi.sh\
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/init.d:system/etc/init.d \
    vendor/lge/thunderc/proprietary/$(SUB_MODEL)/system/etc/hosts:system/etc/hosts
#    vendor/lge/thunderc/proprietary/lib/libsurfaceflinger.so:system/lib/libsurfaceflinger.so
include vendor/lge/thunderc/packages.mk
#PRODUCT_BUILD_PROP_OVERRIDES += PRODUCT_NAME=thunderc BUILD_UTC_DATE=0 BUILD_ID=GRI40 BUILD_DISPLAY_ID=GRJ90 BUILD_FINGERPRINT=lge/thunderc/thunderc:2.3.3/GRI40/LG-P500-V20g.19C11F164C:user/release-keys PRIVATE_BUILD_DESC="thunderc-user 2.3.3 GRI40 LG-P500-V20g.19C11F164C release-keys"
thekraven, do you think trying out your icsa10 manifest is better than the icsa7. I reported an error few posts above and been stuck at it for sometime now. :(
It might only build cm9 with bacon. Try deleting the line in my BoardConfig.mk
TARGET_NO_RECOVERY := true
Otherwise you will need to delete a few lines in the build/core/Makefile
Like this. https://github.com/thekraven/android_build/commit/ce7c27035fd8c8de850f79c9e79e6221a0565b7c
Edit. I haven't pushed anything yet. I finally got it to build with all the new cm changes. So hopefully it boots and works.
It booted up fine, but the P500 stereo files just make static sounds.
Reactions: Invincible Madness
Now I'm getting this:
Its making me feel like a noob.....
(Sorry if my posting screenshots of errors gets annoying. I'm not smart enough to fix them easily)
I am getting that same error. I'll figure it out tomorrow and post the fix.
Please copy text not screen shots. It's much easier to interject comments into text.
Reactions: tvall
thekraven, did you mean that I either have to delete the line from BoardConfig.MK or the edits in the build/core/Makefile?
I deleted TARGET_NO_RECOVERY := true from Boardconfig.mk, repo sync, lunch-4 and make bacon and got this:
Code:
system/core/toolbox/Android.mk:98: warning: overriding commands for target `out/target/product/thunderc/system/bin/lsof'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/bin/lsof'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/etc/mkshrc'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/etc/mkshrc'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/root/init.rc'
system/core/rootdir/Android.mk:42: warning: ignoring old commands for target `out/target/product/thunderc/root/init.rc'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/root/ueventd.rc'
system/core/rootdir/Android.mk:49: warning: ignoring old commands for target `out/target/product/thunderc/root/ueventd.rc'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/etc/hosts'
system/core/rootdir/Android.mk:31: warning: ignoring old commands for target `out/target/product/thunderc/system/etc/hosts'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/bin/dhcpcd'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/bin/dhcpcd'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/egl/libGLES_android.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/egl/libGLES_android.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libmemalloc.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libmemalloc.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/obj/lib/libmemalloc.so'
build/core/dynamic_binary.mk:112: warning: ignoring old commands for target `out/target/product/thunderc/obj/lib/libmemalloc.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/obj/lib/libcamera_client.so'
build/core/dynamic_binary.mk:112: warning: ignoring old commands for target `out/target/product/thunderc/obj/lib/libcamera_client.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libcamera_client.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libcamera_client.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/obj/lib/libcameraservice.so'
build/core/dynamic_binary.mk:112: warning: ignoring old commands for target `out/target/product/thunderc/obj/lib/libcameraservice.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libcameraservice.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libcameraservice.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/hw/audio.a2dp.default.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/hw/audio.a2dp.default.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libril.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libril.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/bin/rild'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/bin/rild'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libmm-omxcore.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libmm-omxcore.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libOmxCore.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libOmxCore.so'
No private recovery resources for TARGET_DEVICE thunderc
Header: out/host/linux-x86/obj/include/libexpat/expat.h
Header: out/host/linux-x86/obj/include/libexpat/expat_external.h
Header: out/target/product/thunderc/obj/include/libexpat/expat.h
Header: out/target/product/thunderc/obj/include/libexpat/expat_external.h
Header: out/host/linux-x86/obj/include/libpng/png.h
Header: out/host/linux-x86/obj/include/libpng/pngconf.h
Header: out/host/linux-x86/obj/include/libpng/pngusr.h
Header: out/target/product/thunderc/obj/include/libpng/png.h
Header: out/target/product/thunderc/obj/include/libpng/pngconf.h
Header: out/target/product/thunderc/obj/include/libpng/pngusr.h
Header: out/target/product/thunderc/obj/include/libsonivox/eas.h
Header: out/target/product/thunderc/obj/include/libsonivox/eas_types.h
Header: out/target/product/thunderc/obj/include/libsonivox/eas_reverb.h
Header: out/target/product/thunderc/obj/include/libsonivox/jet.h
Header: out/target/product/thunderc/obj/include/libsonivox/ARM_synth_constants_gnu.inc
Header: out/target/product/thunderc/obj/include/libwpa_client/wpa_ctrl.h
Header: out/target/product/thunderc/obj/include/librpc/rpc/clnt.h
Header: out/target/product/thunderc/obj/include/librpc/rpc/pmap_clnt.h
Header: out/target/product/thunderc/obj/include/librpc/rpc/rpc.h
Header: out/target/product/thunderc/obj/include/librpc/rpc/rpc_router_ioctl.h
Header: out/target/product/thunderc/obj/include/librpc/rpc/svc.h
Header: out/target/product/thunderc/obj/include/librpc/rpc/types.h
Header: out/target/product/thunderc/obj/include/librpc/rpc/xdr.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/loc_api_cb.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/loc_api_common.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/loc_api.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/loc_apicb_appinit.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/loc_api_fixup.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/debug.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/loc_api_rpc_glue.h
Header: out/target/product/thunderc/obj/include/libloc_api-rpc/inc/loc_api_sync_call.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Audio.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Component.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_ContentPipe.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Core.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Image.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Index.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_IVCommon.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Other.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_QCOMExtns.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Types.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_Video.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/qc_omx_common.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/qc_omx_component.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/qc_omx_msg.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_AudioExtensions.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_AudioIndexExtensions.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_CoreExt.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_CoreExtensions.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_FileFormatExtensions.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_IVCommonExtensions.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_SourceExtensions.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_VideoExtensions.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/OMX_IndexExt.h
Header: out/target/product/thunderc/obj/include/mm-core/omxcore/QOMX_StreamingExtensions.h
Notice file: system/core/libmincrypt/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//lib/libmincrypt.a.txt
Directory: out/target/product/thunderc/root/sbin
Directory: out/target/product/thunderc/root/dev
Directory: out/target/product/thunderc/root/proc
Directory: out/target/product/thunderc/root/sys
Directory: out/target/product/thunderc/root/system
Directory: out/target/product/thunderc/root/data
prebuilt/linux-x86/ccache/ccache prebuilt/linux-x86/toolchain/arm-linux-androideabi-4.4.x/bin/arm-linux-androideabi-gcc -mthumb-interwork -Ibionic/libc/private -DCRT_LEGACY_WORKAROUND -Ibionic/libc/private -o out/target/product/thunderc/obj/lib/crtbegin_static.o -c bionic/libc/arch-arm/bionic/crtbegin_static.S
prebuilt/linux-x86/ccache/ccache prebuilt/linux-x86/toolchain/arm-linux-androideabi-4.4.x/bin/arm-linux-androideabi-gcc -mthumb-interwork -Ibionic/libc/private -DCRT_LEGACY_WORKAROUND -Ibionic/libc/private -o out/target/product/thunderc/obj/lib/crtbegin_so.o -c bionic/libc/arch-arm/bionic/crtbegin_so.S
prebuilt/linux-x86/ccache/ccache prebuilt/linux-x86/toolchain/arm-linux-androideabi-4.4.x/bin/arm-linux-androideabi-gcc -mthumb-interwork -Ibionic/libc/private -DCRT_LEGACY_WORKAROUND -Ibionic/libc/private -o out/target/product/thunderc/obj/lib/crtend_so.o -c bionic/libc/arch-arm/bionic/crtend_so.S
prebuilt/linux-x86/ccache/ccache prebuilt/linux-x86/toolchain/arm-linux-androideabi-4.4.x/bin/arm-linux-androideabi-gcc -mthumb-interwork -Ibionic/libc/private -DCRT_LEGACY_WORKAROUND -Ibionic/libc/private -o out/target/product/thunderc/obj/lib/crtend_android.o -c bionic/libc/arch-arm/bionic/crtend.S
Notice file: system/core/init/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//root/init.txt
Notice file: system/core/liblog/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/liblog.a.txt
Notice file: system/core/libcutils/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libcutils.a.txt
Notice file: bionic/libc/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libc.a.txt
Notice file: bionic/libc/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libc.so.txt
Notice file: bionic/libc/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libc_common.a.txt
Notice file: bionic/libdl/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libdl.so.txt
Notice file: bionic/libstdc++/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libstdc++.so.txt
make: *** No rule to make target `vendor/lge/thunderc/proprietary/LS670/bootimages/opening_01.rle', needed by `out/target/product/thunderc/root/bootimages/opening_01.rle'.  Stop.
make: *** Waiting for unfinished jobs....
Notice file: bionic/libm/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libm.so.txt
Notice file: system/core/adb/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//root/sbin/adbd.txt
Do I need to edit the makefile too? Also, what does Header: at the beginning of a line mean?
Thanks much for the help, I'm really thankful :)
EDIT: I see on pastebin that Jerry got a similar error while building IHO GB, any ideas Jerry?
thekraven, I made the edits to make file too and after reposync and make bacon I got an error saying
need opening_01.rle from vendor/lge.thunderc/proprietry/ls670/bootimages. So I copied all the opening_ files from previous CM9 build I had on the local drive. After make bacon I got this error.
Code:
Notice file: bootable/recovery/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/recovery.txt
Notice file: system/extras/ext4_utils/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libext4_utils.a.txt
Notice file: system/core/libmincrypt/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libmincrypt.a.txt
Notice file: system/core/libpixelflinger/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libpixelflinger_static.a.txt
Notice file: external/libpng/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libpng.a.txt
Notice file: bionic/libstdc++/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libstdc++.a.txt
Target buildinfo: out/target/product/thunderc/system/build.prop
host Java: dumpkey (out/host/common/obj/JAVA_LIBRARIES/dumpkey_intermediates/classes)
/bin/bash: -c: line 0: unexpected EOF while looking for matching `"'
/bin/bash: -c: line 1: syntax error: unexpected end of file
make: *** [out/target/product/thunderc/system/build.prop] Error 1
make: *** Deleting file `out/target/product/thunderc/system/build.prop'
system/core/libmincrypt/tools/DumpPublicKey.java:27: warning: sun.misc.BASE64Encoder is Sun proprietary API and may be removed in a future release
import sun.misc.BASE64Encoder;
1 warning
something to do with syntax error?
If you are building from my device folder its has a lot of experimental stuff. I reverted most of the stuff.
Delete all this stuff. The build.prop error should go away.
https://github.com/thekraven/androi...mmit/bdb8122fbc302b8b67258c03342ef5c477670b5b
Ok, deleted the above lines and got this error:
Code:
target Strip: libc (out/target/product/thunderc/obj/lib/libc.so)
host SharedLib: libSR_EventLog (out/host/linux-x86/obj/lib/libSR_EventLog.so)
host SharedLib: libSR_Core (out/host/linux-x86/obj/lib/libSR_Core.so)
host SharedLib: libSR_G2P (out/host/linux-x86/obj/lib/libSR_G2P.so)
target SharedLib: libz (out/target/product/thunderc/obj/SHARED_LIBRARIES/libz_intermediates/LINKED/libz.so)
target SharedLib: libstlport (out/target/product/thunderc/obj/SHARED_LIBRARIES/libstlport_intermediates/LINKED/libstlport.so)
target StaticLib: libprotobuf-cpp-2.3.0-lite (out/target/product/thunderc/obj/STATIC_LIBRARIES/libprotobuf-cpp-2.3.0-lite_intermediates/libprotobuf-cpp-2.3.0-lite.a)
target StaticLib: liblzf (out/target/product/thunderc/obj/STATIC_LIBRARIES/liblzf_intermediates/liblzf.a)
target SharedLib: libexpat (out/target/product/thunderc/obj/SHARED_LIBRARIES/libexpat_intermediates/LINKED/libexpat.so)
target StaticLib: libft2 (out/target/product/thunderc/obj/STATIC_LIBRARIES/libft2_intermediates/libft2.a)
target StaticLib: libgif (out/target/product/thunderc/obj/STATIC_LIBRARIES/libgif_intermediates/libgif.a)
target StaticLib: libwebp-decode (out/target/product/thunderc/obj/STATIC_LIBRARIES/libwebp-decode_intermediates/libwebp-decode.a)
target StaticLib: libwebp-encode (out/target/product/thunderc/obj/STATIC_LIBRARIES/libwebp-encode_intermediates/libwebp-encode.a)
target thumb C++: libbinder <= frameworks/base/libs/binder/Parcel.cpp
target thumb C++: libbinder <= frameworks/base/libs/binder/ProcessState.cpp
target thumb C++: libbinder <= frameworks/base/libs/binder/Static.cpp
frameworks/base/libs/binder/Parcel.cpp:20:1: warning: "_INTERNAL_BINDER_PARCEL_" redefined
<command-line>: warning: this is the location of the previous definition
frameworks/base/libs/binder/Parcel.cpp:488: error: prototype for 'bool android::Parcel::enforceInterface(const android::String16&) const' does not match any in class 'android::Parcel'
frameworks/base/include/binder/Parcel.h:77: error: candidate is: bool android::Parcel::enforceInterface(const android::String16&, android::IPCThreadState*) const
make: *** [out/target/product/thunderc/obj/SHARED_LIBRARIES/libbinder_intermediates/Parcel.o] Error 1
Do you think, using the device and vendor folders I forked from yours will make it easier?
Look back a few pages, there's a binder commit to revert or do tdm's boardconfig.mk edit.
Ok, fixed that error by placing parcel.o fromt he old build folders and some more errors came that I could fix by editing config.XML. It ran for a pretty good time and got stuck at this error:
Code:
----- Making recovery image ------
out/host/linux-x86/bin/mkbootimg  --kernel out/target/product/thunderc/kernel  --ramdisk out/target/product/thunderc/ramdisk-recovery.img --cmdline "mem=471M console=ttyMSM2,115200n8 androidboot.hardware=thunderc" --base 0x12200000 --pagesize 2048 --output out/target/product/thunderc/recovery.img
----- Made recovery image -------- out/target/product/thunderc/recovery.img
out/target/product/thunderc/recovery.img total size is 5185536
target Strip: libGLESv2_dbg (out/target/product/thunderc/obj/lib/libGLESv2_dbg.so)
target Strip: libhardware_legacy (out/target/product/thunderc/obj/lib/libhardware_legacy.so)
target SharedLib: libskia (out/target/product/thunderc/obj/SHARED_LIBRARIES/libskia_intermediates/LINKED/libskia.so)
target Symbolic: libstagefright_foundation (out/target/product/thunderc/symbols/system/lib/libstagefright_foundation.so)
Install: out/target/product/thunderc/system/lib/libGLESv2_dbg.so
Install: out/target/product/thunderc/system/lib/libhardware_legacy.so
target Symbolic: libdrmframework (out/target/product/thunderc/symbols/system/lib/libdrmframework.so)
target SharedLib: libchromium_net (out/target/product/thunderc/obj/SHARED_LIBRARIES/libchromium_net_intermediates/LINKED/libchromium_net.so)
Install: out/target/product/thunderc/system/lib/libsqlite.so
Install: out/target/product/thunderc/system/lib/libdefcontainer_jni.so
Install: out/target/product/thunderc/system/lib/libttspico.so
target SharedLib: libbluetoothd (out/target/product/thunderc/obj/SHARED_LIBRARIES/libbluetoothd_intermediates/LINKED/libbluetoothd.so)
frameworks/base/core/java/com/google/android/mms/pdu/PduParser.java:1567: cannot find symbol
symbol  : variable config_mms_content_disposition_support
                                .android.internal.R.bool.config_mms_content_disposition_support);
Install: out/target/product/thunderc/system/lib/libbtio.so
Symlink: out/target/product/thunderc/system/bin/cat -> toolbox
Symlink: out/target/product/thunderc/system/bin/chmod -> toolbox
Symlink: out/target/product/thunderc/system/bin/chown -> toolbox
Symlink: out/target/product/thunderc/system/bin/cmp -> toolbox
target Symbolic: dalvikvm (out/target/product/thunderc/symbols/system/bin/dalvikvm)
target Symbolic: dexopt (out/target/product/thunderc/symbols/system/bin/dexopt)
Copy: out/target/product/thunderc/system/bin/dhcpcd
target Symbolic: dumpsys (out/target/product/thunderc/symbols/system/bin/dumpsys)
target Symbolic: libpowermanager (out/target/product/thunderc/symbols/system/lib/libpowermanager.so)
Install: out/target/product/thunderc/system/bin/netcfg
target Executable: netd (out/target/product/thunderc/obj/EXECUTABLES/netd_intermediates/LINKED/netd)
target SharedLib: libril (out/target/product/thunderc/obj/SHARED_LIBRARIES/libril_intermediates/LINKED/libril.so)
target Symbolic: service (out/target/product/thunderc/symbols/system/bin/service)
Install: out/target/product/thunderc/system/lib/hw/gps.goldfish.so
Install: out/target/product/thunderc/system/lib/hw/gps.thunderc.so
Install: out/target/product/thunderc/system/lib/libdrm1.so
frameworks/base/telephony/java/com/android/internal/telephony/gsm/GsmDataConnectionTracker.java:280: cannot find symbol
symbol  : variable networkAttributes
                com.android.internal.R.array.networkAttributes);
target Executable: vold (out/target/product/thunderc/obj/EXECUTABLES/vold_intermediates/LINKED/vold)
target SharedLib: libdrm1_jni (out/target/product/thunderc/obj/SHARED_LIBRARIES/libdrm1_jni_intermediates/LINKED/libdrm1_jni.so)
Install: out/target/product/thunderc/system/lib/libexif.so
target Symbolic: libmtp (out/target/product/thunderc/symbols/system/lib/libmtp.so)
target Symbolic: libbcc (out/target/product/thunderc/symbols/system/lib/libbcc.so)
target Symbolic: libsqlite_jni (out/target/product/thunderc/symbols/system/lib/libsqlite_jni.so)
Install: out/target/product/thunderc/system/lib/soundfx/libaudiopreprocessing.so
Install: out/target/product/thunderc/system/xbin/btool
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
2 errors
target Symbolic: sqlite3 (out/target/product/thunderc/symbols/system/xbin/sqlite3)
target Symbolic: su (out/target/product/thunderc/symbols/system/xbin/su)
Install: out/host/linux-x86/bin/sqlite3
Install: out/host/linux-x86/lib/libsqlite_jni.so
Construct recovery from boot
mkdir -p out/target/product/thunderc/obj/PACKAGING/recovery_patch_intermediates/
PATH=out/host/linux-x86/bin:$PATH out/host/linux-x86/bin/imgdiff out/target/product/thunderc/boot.img out/target/product/thunderc/recovery.img out/target/product/thunderc/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p
make: *** [out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/classes-full-debug.jar] Error 41
target SharedLib: libEGL (out/target/product/thunderc/obj/SHARED_LIBRARIES/libEGL_intermediates/LINKED/libEGL.so)
failed to reconstruct target deflate chunk 1 [(null)]; treating as normal
Construct patches for 3 chunks...
patch   0 is 203 bytes (of 3248138)
patch   1 is 1180128 bytes (of 591572)
patch   2 is 179 bytes (of 290)
chunk   0: normal   (         0,    3248138)         203
chunk   1: deflate  (   3248138,    1936952)     1180128  (null)
chunk   2: normal   (   5185090,        446)         179
tried a couple things but this ain't going away.
Lelix2603
