[DEVS ONLY] ics repo
When I do
Code:
repo init -u git://github.com/anathma/android.git -b icsa7
I get
Code:
fatal: manifest 'default.xml' not available
fatal: remote gh not defined in /home/anathma/android/AOKP/.repo/manifests/default.xml
I forked thekraven's android folder and edited the default.xml
from
Code:
<remote  name="chaos"
           fetch="git://github.com/BobZhome" />
to
Code:
           fetch="git://github.com/anathma" />
where am I doing it wrong?
EDIT: Fixed. Thanks gannon.
now on . build/envsetup.sh I get no such file or directory
Code:
anathma@icsbox:~/android/AOKP$ . build/envsetup.sh
-bash: build/envsetup.sh: No such file or directory
LOL, same here, I tried for two days to build from Bob's source, only to find out he was updating little bits all through my efforts. Decided I should wait a while till things slow down a bit. ;)
I get this error at make bacon:
Code:
target Java: MagicSmokeWallpapers (out/target/common/obj/APPS/MagicSmokeWallpapers_intermediates/classes)
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
target Java: MediaProvider (out/target/common/obj/APPS/MediaProvider_intermediates/classes)
target Java: Mms (out/target/common/obj/APPS/Mms_intermediates/classes)
target Java: NoiseField (out/target/common/obj/APPS/NoiseField_intermediates/classes)
packages/providers/MediaProvider/src/com/android/providers/media/MediaScannerService.java:175: getExternalStorageState() in android.os.Environment cannot be applied to (java.lang.String)
                if (Environment.MEDIA_CHECKING.equals(Environment.getExternalStorageState(path))) {
Note: packages/providers/MediaProvider/src/com/android/providers/media/MediaProvider.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 error
make: *** [out/target/common/obj/APPS/MediaProvider_intermediates/classes-full-debug.jar] Error 41
make: *** Waiting for unfinished jobs....
Note: Some input files use unchecked or unsafe operations.
DroidDoc took 25 sec. to write docs to out/target/common/docs/api-stubs
make bacon again and I get this: http://pastebin.com/j7jA4K2c
Code:
1 error
make bacon again and I get this: target Java: MediaProvider (out/target/common/obj/APPS/MediaProvider_intermediat - Pastebin.com
I'm getting it too.
I'm googling for the past 90 minutes with no avail. Let me know if you find a fix ;)
Looks like some changes might be being pushed. Give it a few hours, re-sync, then try again.
I guess Jerry's right. But something is wrong with their MediaProviders, so for the time being I synced it with another and it seems to be doing good. I have a zip right now and am about to test. Lets see how this goes :)
If you're pretty sure that someone upstream (eg. the CM team) broke the build with a recent commit but you don't know which commit or where to look, you can try rolling back in time past the offending commit. Something like this (untested):
Code:
repo forall -c git checkout ics@{1 hour ago}
Blarf rearranged the repo. You will need to update your manifest. Warning it should build but JerryScript was having trouble with the cell radio.
Anyone else having issues with building cm9? Mine yesterday after sync started failing at libmedia (screenshot below)
I'm assuming this is a cm issue (building from a fresh sync with the files tdm posted + webrtc patch and tdm's cm build tools fix)
Click to view quoted image
Here's bobs fix, though I get a different error later into the build.
"In BoardConfIg.mk, make sure to use BOARD_USES_QCOM_HARBWARE:=faIse"
Thanks Bob
Sent from my VM670 using Tapatalk
Hey sellers86, who's repo are you building from for ICS?
Anybody getting this?
make: *** No rule to make target `frameworks/base/core/java/android/app/IProfileManager.aidl', needed by `out/target/common/obj/JAVA_LIBRARIES/framework_intermediates/src/core/java/android/app/IProfileManager.java'. Stop.
Lelix2603
