Disable screen lock on Huawei Mate 10 Pro
Nesdam1981
5
Hey peeps.
Any know how to entirely disable the system screen lock on Huawei Mate 10?
There's no option to disable it, at all. There's only options to remove security (pin, pattern and password) and the only work around I found don't seem to work on the newer devices.
The old work around was something to add a backup password with pattern lock and then use wrong pattern untill the backup password kicks in. That would disable the lock screen.
That work around seem to be patched and now there's no way to turn off system lock.
So if using a custom lock screen you're stuck with two lock screens...
Ok, I actually solved this. the turn off lock screen is hidden in the developer settings. So for anyone else having issues you need to enable the developer settings and then go in there. The option to turn off lock screen is in there.
Taylor Bag
