Discussion for - Root, Recovery, and ROm without touching a computer
I just ordered a new optimus t and new to the optimus t (comming from optimus v) will this new v10s firmware be on a new phone?
Re: Discussion for - Root, Recovery, and ROm without touching a c
Thank you. Doing it right now
Will all compatible roms work with this method. I see where some roms say to use specific recovery methods. Rom suggestions ?
I am trying to use z4root to root my optimus t. It keeps saying USB debugging must be enabled even though it is enabled.
quick question i used this method to mod my phone , but im thinking of trying cm7 was wondering if the recovery is compatible to flash cm7 or should i re mod the phone to a different recovery.
hell, i am having an issue as to the zip files won't let me paste them on root folder. or do i need to make a root folder in the SD card?
I'm having the same problem as jasonmatty. It says USB debugging must be enabled, even though it is enabled. Is the phone supposed to be plugged into the USB ?
just let you guys know Gingerbreak will work with v10s firmware(android 2.2.2)
[26.04.2011][v1.2] GingerBreak APK (root for GingerBread) - xda-developers
Ditto.
On v10s, z4root just exited after a while and would not complete and no superuser on manual reboot.
GingerBreak-v1.20.apk worked. Original thread should be updated.
Used this thread to install Recovery since links in original thread are broken.
can the op please reupload the RA-GNM-OPT-T-test.img.zip again? When I click on the link it gives me an error message saying file not found, thank you.
Read the last line of my post right above yours for the link to a recovery install process that works.
Ditto.
Used ]this thread to install Recovery since links in original thread are broken.
Which recovery img did you use off of that? I tried one last night and temporarily bricked my phone. I did get it back up and running. I used the thunderg 2.2.1.
BobCat6767
