Does anyone's S3 pair automatically in car?
I just tried a last ditch effort with this phone where I did a factory reset. I also removed all devices from the car (Honda CRV). I then starting the paring process again and it seemed to pair automatically but after I downloaded/accessed my phonebook/contacts it stopped working. I read somewhere the phonebook may cause the problem with pairing. Those whose phone's work are you accessing the phonebook?
Thanks again.
Thanks again.
I can access the phone book with no problem on my Ford Sync system...
The only issue I have ever had is that if I have not turned my Bluetooth on before starting my car I have to do the pair manually on the phone by going to the BT device available. If I have BT on and then start my car it connects automatically though. (Hyundai accent with Sony aftermarket radio.)
Sent from my SCH-I535 using Android Central Forums
My S3 will automatically connect to both my cars if BT is on before I start the car.
If i turn on the S3's BT after the car is on, it will only auto-connect in my Audi. My Porsche will not connect automatically if the phone's BT wasn't on first. However, this is NOT unique to the S3 - behavior with these two cars was the same with my iPhone and with my GNexus.
Mine pairs automatically, every time (and I have no issues accessing my contacts through my car) -- I drive a Hyundai, Tucson.
Not that it helps, but yes my G3 connects every time with out a hitch. I drive a Chevy Equinox.
I use the iBolt car dock and have Car Home Ultra set to turn Bluetooth on automatically when connected. It connects every time with my 2010 Audi
A4.
I also have Car Home Ultra set to turn Bluetooth off when I disconnect it from the dock.
No problems whatsoever.
Mine pairs automatically to my Acura RDX, but it takes a few minutes for the audio to start playing thru the speakers.
Anyone else have this issue?
And all you guys are on VZ?
Mine won't auto pair and I have to re sync everything each time I start the car.
It won't even show what song is playing either even when it is synced.
I thought we were talking about the phone not pairing (which I have no problem with). I don't have bluetooth capable music in my car.
Mine pairs fine with my car.Both the stock Vzw ROM and with CleanRom 2.0.1
I just have to remember to delete the old sync from stereo after I flash a new ROM before resyncing phone.
Dodge Charger 2011
sent from my S3
2011 Kia Optima here. My S3 pairs immediately only half of the time. The other times, I have to toggle my BT off/on and manually pair. And sometimes it will eventually pair after 10-15 minutes.
My Galaxy Nexus would NEVER pair with my car automatically.
2010 civic SI with a Kenwood DNX-9960 bluetooth/navigation DDin installed and it connects every time I start the car with no problems
Do you use the S Voice in the mercedes? I can pair my S4 BT to my C350, but then S Voice doesn't respond to my voice. I can still make calls through the BT by selecting the contact and dialing on the phone, but S Voice is nonresponsive.
Let me know you're experiencing this problem.
kalikama1
