does galaxy s3 have same problems as the nexus on verizon?
droid747
384
8
Has anyone heard if the s3 has the same problems as the nexus on Verizon? Specifically the weak signal and microphone mute issues.
anon(94115)
Banned
Nov 29, 2010
5,697
511
Well since it was announced today, and won't be out for weeks, I cannot see how anyone could . I will go out on a limb (with some experience) and say the signals will not be up to what you would get with HTC or the like, BUT SoC might change that. I come back with, no one can or does know at this point.
Figure it comes out on the 21st, we will know by the 22nd
Bulkybear
Active member
May 27, 2011
44
Yes... both are on Verizon. :p
The signal issues on the gnex aren't on verizons end. A lot of faulty hardware. Weak radio. And software are mostly what's causing gnex issues. To the OP the best I can tell you is wait for the reviews. Sammy may have learned from the gnex. And it IS entirely possible they purposefully skimped on the gnex to put the s3 in a better spot. I mean what would you do if you had to build googles flagship phone and also build your own companies flagship?
Sent from my ADR6400L using Tapatalk 2
LazrRocketArm
796
64
Ok, it has the same SoC as the One X. So it has the same radios, right?
Qualcomm should be decent. Good in my Skyrocket.
Sent from my Samsung Galaxy S2 Skyrocket SGH-i727 on ATT LTE
jackybeny
