Does "Smart Stay" actually work for anyone?
PsychDoc
1,402
7
38
I think it's a great feature but one that simply doesn't work. I have it set to on and it seems to do nothing. The only indication I can see that it's even engaged is a little eye icon appears briefly in the notification bar right before the screen goes dark.
Talk about counterintuitive. Shouldn't that be the signal that it's aware that I'm looking at the screen and then stay lit? Instead it appears 2"-3" before the screen shuts down.
Have any of you gotten this feature to work properly?
Any advice or feedback would be greatly appreciated.
Sent from my SM-G900V using AC Forums mobile app
Works OK on my S5, but only when screen is almost vertical.
When lowered to horizontal next time the screen is due to go off it will about 3 seconds after the little eye appears.
Mine used to work perfectly. In fact I suggested to someone here to turn it on so their lock screen would stay on longer. But lately it's kinda finicky. I knew from having my GN/2014 since last Christmas that if the room was darkish or eyes half closed, it wouldn't work. I have my screen timeout set to 2 minutes. I tested it this morning and it didn't work. I turned the feature off and then back on and set the timeout to 30 seconds (just so I wouldn't have to wait so long) and it worked several times in a row. Turned it back to 2 minutes and it worked...then it didn't. I don't know what's going on with it. It *seems* like this started around the same time my phone started turning on by it's self. Still haven't figured that out (but haven't tried too hard yet either).
I have it on all the time but didn't realize it works on the lock screen. I just tried it and it kept it open longer than usual but I had to take my glasses of in order for it to work. It eventually stopped, probably due to the fact that I am in a low light room. I haven't had any problem with it that I'm aware of.
On my S3 it worked perfectly
On my S4 it didn't really work too well
On the S5...I have it off lol
If you have glasses it will nullify it as well...
I'm in my bed now, it is 930 am, wearing my glasses, holding the phone above my head horizontally and it is working absolutely perfectly...
Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
lordnico86
