Double Tap=Screen On
DakotaBoy
Active member
Aug 8, 2013
33
Seems like a wicked awesome feature. This and a good camera is enough to make me sell my One.
Really ? I will hold off to use this phone in store but I'm disappointed in the storage options (32gb and 64gb come on people!!) software seems boring, it needs a bigger battery, global lte? to name a few things :(
IIRC this is available on hTc One by Rooting which is too bad because I'm not comfortable doing.
Anyways, when I saw this and other LG's features it got my attention. I thought I was set with Samsung Galaxy Note 3 hTc One Max but this changes everything.
SHIFT_note 8.0 lte
Until you realize double tap = screen off = killing of launcher features. I'm terribly unexcited about that.
I'm good with AT&T. Battery life is definitely a concern though. Do you guys think the double tap feature will work if I'm running Nova Launcher? I'm not sure if I'm a fan of LG's UX. @ bembol, I'm not into rooting either.
What? 32 and 64 GB are not enough? Am I reading that right?
Software is nothing to write home about, they took a page right out of the Touchwiz ugly book, but that is what launchers are for
Bigger battery? 3000Mah is the biggest battery, in a normal sized (4.5-5") phone outside the Maxx. It is rated to go 1.2 days, but even if it makes 18 continuous hours it is a step up.
Global LTE doesnt concern most of us, but ok I hope that what ever country you are from you get LTE. I am sure all the ones here in the states will
Your pretty much off the mark on everything here except maybe the software, and that really has yet to go through any kind of practical use/review
Amen! I really hope this phone gets decent reviews. Whatever LG calls their android skin looks pretty ugly, but I could get used to it, if launchers took away the double tap thing. I am a recent iPhone 5 convert (since chromecast). And I would say that the one thing I really don't like about my One is that its tough to use with one hand. But, double tap screen thing, software buttons, and rear buttons could alleviate that issue.
No, this is a separate thing. You can use launchers like Nova to enable a double tap gesture to hide your status bar up top (pull down) or do other things. I used this extensively before I switched to Action Launcher. Action Launcher has a tap to hide the search bar which I use, however oftentimes I'll accidentally double tap. This would turn off my screen rather than hide an element of the homescreen. It may not be a big deal to you, but it is for a contingent of people which includes myself.
This isn't the same thing. This turns your screen on from being completely off.
I had this on a lumia 925 I had for about a week, and I still find myself trying to double tap my Nexus 4's screen to wake it up. It should be a standard thing on phones without physical buttons on the face. (Or, software like the Moto x's as well)
Not everyone will use the same launcher, you are using. So this is a issue for you, and the phone might not be for you.
I've been enjoying double tap to wake on the bottom inch of my HTC one screen. I also have long press htc logo to wake or sleep & swipe right across capacitive area to wake and left to sleep. I also have volume keys as wake. I wonder why for instance Htc didn't map the htc logo to menu as I did with a custom kernel. The double tap to wake thing would be cool out of the box as well.
Unlocking the bootloader brings a whole new world to the one. It's well worth it and really is not dangerous if you follow directions. Dual booting stock android and htc sense 5? Priceless.
AT&T HTC One MoDaCo.Switch Beta 8
Nexus 7 2013 Unlocked Root + TWRP
Chromecast
Uuuum my note 2 battery is 3100mah and its a beast sooo this s battery with a smaller screen and better screen technology to save battery should be even better.... At the point people complain about a 3000mah battery... Im thinking.. U just wanna complain.. Sorry that's plenty.. And I'm a heavy user
Sent from my SCH-I605 using AC Forums mobile app
this is not a problem seeing as all the UI additions can be cut off. The knock, the Qslide, the volume presses all that stuff can be cut off. no manufacturer implements their extras without letting you disable them.
Wow, what a giant liar.
And do you know who created this functionality? I do. and I know it isn't possible
Let me give you a hint, the same functionality is in the HTC ONE. It's called Swipe to Wake Up, it's just the gesture that's different. (Double tap also exists on HTC one)
hTC One - Swipe To Wake and Logo To Wake Up - YouTube
Double tap is awesome.
If I can double tap my SIG or Springfield, then I should be able to double tap my phone!
'MURRRICA!!!!
I use double-tap in browsers to size to the current column a LOT.
Double tap to turn the screen OFF will only work on a "dead space". If you have an app open, like your browser, normal app rules will apply to double tap. Also, if you try to double tap a widget then it'll just do whatever double tapping a widget normally does.
Basically, you have to double tap an empty space on your homescreen to turn the screen off.
I already use this feature to turn my phone off with auto screen off and nova launcher.
Sent from my HTC One
kctraci1
