DQA urgent update
Ok... Everyone re-enable dqa first if you disabled it with the package disabler app. I did not, so the update didn't take.
I went into app settings and force closed Galaxy apps, and cleared the app cache and data, rebooted my phone and was asked to do the update again.
Just an fyi,
Wife "swooshed" hers away. Restarts and anything we tried couldn't seem to retrigger it.
Did a factory reset for a different issue and it reappeared..
DQA Update
So I just got a message about this and was wondering if I should do it? I am not having any problems with the phone having popups about anything. Thanks for the replies
Re: DQA Update
Yes you should do it.
Re: DQA Update
What does it do? id I do or if i dont
It is bug fixes. That agent handles wifi and other things -- Samsung noticed a bug with it and is fixing it so it runs properly.
Re: DQA Update
well now when i go to system updates i dont show anything. it just popped up today and now it isnt there
Re: DQA Update
Go to your app drawer and open "Galaxy Apps". It should be there.
Thanks for posting this since I tried to disable it prior to installing the update but couldn't find the update after that.
liquidsnake757
