Droid X stuck on boot screen/battery fell out durring formating
N3XUS11
4
ok I was using MIUI then i saw the beta for a CM 9 rom, so i thought ill try it, i was going to do a backup and a factory reset, but when i looked i saw formatting and i was not sure if i actually checked back up and wipe in Rom manager and if i kept wipe devic checked, so i pulled the battery to start over but now my stuck on my boot screen.
Does my Phone have a rom on it and if not how can i fix it , i dont now how to get to recovery am only able to get to Stock Recovery, PLEASE HELP:confused:-X
Re: Droid X stuck on boot screen/battery fell out durring formati
Can you sbf it?
Whats That? i this is the first time i had a issue
Pulling out a battery while in bootloader or recovery always scares me. I wish I had an answer for you, but I'm not that smart. I'd probably asked in the DroidX forum though.
I went moments after posting this , they helped me out , SPFing was not as hard as I thought
Sent from my DROIDX using Android Central Forums
HourFromNow
