Droid X Unsuccessful installs from the Market
Yes, go into your settings/ applications/ find market & clear data & force stop than reset
1.21 giggawatts of Thunder
Two things.
Firstly, make sure you have enough space on your internal storage. If there isnt enough space your installs will fail.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select SD card & phone storage.
5. Check under internal storage.
Secondly, if you do have enough space you can try going to "Manage Applications" find Market. Then clear data and clear cache. Go back to the Market app and try again.
Did not help. Same symbol/error message. A yellow triangle with and exclamation point inside. I am very unsophisticated so don't want to remove SD card.
Crissy Doug
