DroidMod 1.0 Question
Touch the weather area, Hit Menu, Hit Settings, Hit Weather Settings, Make Sure "Use Celsius" is not checked off.
Also make sure you uninstalled the .24 version if not it will not work.
C is not checked. Also yes I uninstalled previous version now running 1.1.7 RC6, installed form the link your provided earlier.
This is definitely an issue I saw - I've been using the Gentle Alarm dock screen since then, it's not a true fix to the issue, but it is a reliable workaround if you already own gentle alarm - if you don't, go buy it! It's pretty neat.
fummy, I never had that problem.
However, glad you got it working. DA6 - you da' man. (get it? DA' man, DA6?? get it? - come on that was good.)
MichaelCrusan
