drop calls on T-Mobile S6 Edge
prettylady34
10
Is anyone getting drop callas with the edge on Tmobile? I drop on Lte with all 5 signal bars. I can be on a call n it will drop or someone can call me and the call drop. Location Arlington Tx.
I'm having the same issues in New Orleans. The network is pretty disappointing, and even using wifi calling at home or work subjects the phone to dropped calls far more frequently than I'd think possible in 2015.
If you have Wifi calling and VoLTE on turn it off both and see if it helps.
The problem I have with T-mobile coverage here is that there is none inside most buildings, including both home and work for me. Unless there's a solution I'm overlooking?
I'm using Telekom (german version of T-Mobile) and it's better than every provider I've ever had. No phone call drops and almost everywhere I get LTE.
removalboxes
