Dual Port Wall Charger
NismoZ
117
So, i found that not all wall chargers are created equal. The Samsung charger that came in the box was the fastest by far over my other cheap ones.
I am assuming a need a full 1amp output (1000ma) on each port. And one that will charge 2 Galaxy S2s at teh same time at full power.
Does anyone know of the best one available?
I think most current smartphones use 1Amp chargers. Even my old Palm Pre charger was 1Amp and it charges fine. The generic or older chargers might be 0.5 or some other output that's lower which is why they would charge slower.
If you really want to be safe you can probably buy 2Amp chargers, which I think is what most tablets use. Otherwise I think you'll be fine with any 1Amp.
thatbizarregal
