kigmatzomat
- Jun 4, 2013
- 50
- 0
- 6
I used to agree, but Box has made changes the last few months that I really like. Their UI now works a lot like dropbox did.
The Box UI may be similar to Dropbox but there are some big differences under the hood, especially on the PC side where synching is concerned. I recently upgraded my computer. Getting my data on the new PC was easy with dropbox. I just copied the Dropbox folder across and Dropbox sync spent about a half hour validating the files and all was good. Note that this wasn't using the Drobox lan sync, I just restored the files from my NAS.
Box had several hissy fits. First off, the new Box 4.0 client requires jumping through a lot of hoops to get it to point somewhere besides the c:\ drive. I've got an SSD for C: and a bigger spinning disk where I keep my synched data. I had to go through Box support until a point release supported using the D: drive. Then it turns out tere is NO support for simply copying the files from the old hard drive to the new one. I got a billion errors about file name conflicts and Box starting downloading copies of files I already had. It turns out that Box either wants you to re-upload the files or re-download the files from their servers. I have 95GB of data being synched; that would take a month. The files are sitting right there on my NAS! Gah.
