kigmatzomat
- Jun 4, 2013
- 50
- 0
- 6
serious question: why are some folks saying box has syncing issues? i've never had a problem in the least....what am i missing?
I never had a problem with box until I got a new laptop and tried to migrate from the old one. First off, the new box software for Windows doesn't support custom locations without editing registry keys. I have an ssd for my os and cache and a bigger spinning disk for data, which is where I want box. Took me three installs before I figured out what happened and then got the right sequence of events to work.
Then I had 45GB of data to migrate. It was all on the old laptop and my NAS but could I copy the files over? Nope. I either had to re upload them or re download them. All the local copies got renamed and duplicated. Ugh. Over DSL that takes weeks.
Dropbox, however, just did a scan of the folders, calculated a bunch of hashes and said all was good. I could have used the lan sync to migrate the data but it was already on the disk from where I copied all my data over, not just my cloud data.
I haven't tried gdrive but one of the things I try will be to synch some data, uninstall the client, and see if it will recognize the data on my laptop is a match our if it will require it all to be reloaded from the cloud.
