Excellent fingerprint and facial recognition
Is it a glass protector that doesn't use the liquid like the others like or doesn't use adhesive on the entire underside like what you would find in an iPhone tempered glass protector and only a strip of adhesive on the edges??
I've tried a couple on my Note 8 and even though it didn't have FPS sensor I always ended up going with the Spigen UltraFlex TPS because no matter how flat against the glass it may seem, there is that tiniest bit of space that is there to keep from getting a good touch. The liquid protectors fill in that gap. A full adhesive I guess would but never seen one.
TPS even though not the same smooth feeling, my first attempt, seems to be working for me fortunately so sticking with Spigen again. LK mentioned by another sounds like a good option too because it's a dry application where the Spigen is wet so I may try that when time to change protectors.
So, I initially set up FPS on my Note20 and as all said, it works very fast and accurately. But when I put on a glass screen protector, it would not recognize FPS 100% of the time. I thought it was the glass screen protector, so I sent it back and ordered another one. Removed all stored fingerprints and attempted to redo WITH the screen protector on and Touch Sensitivity on - NO DICE. So, I guess I need to remove the glass screen protector, set up the FPS, and then reinstall a glass protector or forget and go with a TPS one? Thanks in advance for suggestions.
Actually, I had the worst time getting my fingerprints scanned in.
I can't say anything about facial recognition. I'm not going to set it up on my Note 20. The Note 9 will probably be the last Samsung phone that I will be setting it up on.
It's funny you say that. Perhaps because I wear glasses the Note9 iris scanner or facial recognition doesn't work at all.
I like the fingerpint sensor on the back. It will be hard to get used to doing it in the front.
Big improvement over the 10+ was I have no issues unlocking with my fingerprints or facial recognition feature. This was the first thing I tried before purchasing the note 20 didn't want to spend over 1000 on a device with a poor sensor again.
Even now after about 3 weeks both face recognition and fingerprint has been working flawlessly, Samsung really nailed it this time (and about time too LOL)
I'm not having great results with fps either. It doesn't want to recognize my FP with certain wallpapers on lock screen & I need to do it multiple times before it recognizes my print. I did register both of my thumbs, twice, I don't have a screen protector on and I even increased the phone screens sensitivity. So yeah, I'm pretty bummed bc I was really looking forward to the in screen fps on N20U.
Very surprised mine is snappy and spot on everytime!!
Mine works great now that I took off the screen protector. Followed Jimmy is Promo video and registered both thumbs under one print.
TheGreatApe00
