Extend "Automatically Lock" beyond 30 minutes?
Oldwisewiz
Active member
Nov 27, 2015
26
Settings/Security/Automatically Lock only gives me 30 minutes max. I don't use Location settings, so Smart Lock is out. At home, I would like to have the screen go to sleep after a minute of inactivity, but the Lock only kick in after two hours or so, or better, only after I tell it to lock somehow. I have searched for hours for an answer and can't find what I need. I can't believe thousands of others don't want the same flexibility.
Anyone know a good method of achieving what I want?
You might want to check out Tasker, although I can't say for sure that it can do what you're looking for.
Thanks, B. I took your suggestion and had a good look at Tasker. Actually, I think Tasker is a case of overkill for the one option I'd like to have available, but looking it over and reading about it led me to another app that's less complex and says it does what I want it to do and not much else. I'm checking out Lock Delay now, and will move to trying Tasker if that doesn't pan out. Thanks again for responding. Happy whatever you're celebrating!
Yes, sorry, I mis-typed it. Delayed Lock it is. But it doesn't seem to work on my Moto E 2015 unless I set up the Location plug-in, and that requires that Location Services be on, but the built-in Lollipop Smart Lock does just fine with Location Services on.
I gave it about four hours of testing before I gave up, turned my Location back on, and set my Smart Lock to my home location.
Drat! The app looks brilliant, and the author is obviously attentive to users' probs, but he can't do anything about Motorola or Lollipop 5.
Any "something else" suggestions?
Thanks again, B. I was afraid that might be the case. BTW, Nazarian does a pretty good job of making info available. Appreciate your help and your link.
Wisewiz
UPDATE UPDATE UPDATE!
Wrote the developer, tried the app some more, even though I was not optimistic, given that I'm on the ornery Lollipop, and IT WORKS, and without that can-of-worms Location Services! Don't even need the Location plug-in (which, in any case, requires Location Services). Thanks, B. and all of you who read this thread.
