Extended battery
kcdee00
Active member
Jul 13, 2012
27
Where's the best place to buy an extended battery for the gsm nexus?
Does anyone know if the CDMA/LTE (Verizon) stock battery will fit into the GSM GNex? I previously had the Verizon GNex and now have the GSM GNex.
got mine on ebay from "shimshop" make sure to go to the listing that includes the battery and the extended battery cover. ordered on 7/9 and received 7/19. not bad considering it was an international parcel.
it is not compatible. dimensionally they are actually quite different.
Seidio. Excellent quality competitive pricing.
I bought the gsm specific seidio 3500 mah battery and cover and holster from Amazon. Very happy so far, but it has only been a few days of use.
I've ordered mine from etradesupply, a 3800 mah battery only cost $12. I think it worth a try.
Those batteries aren't very good. You will get slightly better battery life than stock, but not anywhere near a quality battery.
Went through the same thing I the original epic. Cheap eBay battery ended up killing it
Will it actually damage the phone in any way, or at worst, will it just offer a sh*itty battery experience? For 12 dollars, it seems worth a try just to see, unless it damages the phone of course..
this is the best source. it's the OEM samsung extended 2000 mAh battery for the GSM GNex, and comes with the battery door that will fit it
I thought the OEM extended was supposed to be 2100mah?
reblkari666
