External hard drives not working
Hi
FWIW, the drive format that works (for me) is exfat.
If you format a portable hard drive as exFat it works with Android, Windows and Mac. Great for file transfer between these devices.
One of the BEST things about the Galaxy Note 3 is its USB 3 connector. I don't know why they changed it back to the micro USB???
The USB 3 connector allows DIRECT connection and POWER TO USB 3 portable hard drives. (This does require the OTG cable). I started with a 1tb Toshiba drive. This worked exceptionally well until the drive died. At this point I changed to a Seagate 2TB drive.
The drive was formatted as exFat and is fully functional and accessible as a 2TB drive directly from the Galaxy Note 3.
This means I can read and write up to 2TB of data directly to and from the drive that is POWERED by the Galaxy Note 3 battery!! I do not know how long this would last as I have never timed it, but the drive "powers down" after a period of inactivity. Accessing the drive causes it to spin back up and work as normal. This is "the best thing since sliced bread" :D
I do have a 250gb SSD that came out of my PC when I upgrade the PC to a 500gb SSD. This also works and probably draws less power than the normal (Seagate) hard drive.
I was very disappointed to find that the Galaxy Note Pro 12.2 with a much lager battery capacity, DOES NOT power the Seagate drive.
kind regards
Peter
I guess the Tab S isn't compatible with Seagate hard drives. I've got a 1TB that I can't get to work. I'm trying to connect with a powered OTC. I guess they want you to buy Samsung drives. I might as well just get a 256GB flash drive. RIDICULOUS!!!
Try "MLUSB mounter" from Play Store.
After I downloaded it to my Android device and plugged it into MyPassport external drive, MLUSB mounter read the external drive and I could move files back and forth between the Android device and MYPassport. It's free and no special permissions are needed.
There are two things at fault here the Android version and Samsung Android is Linux partitions and the ext4 format it can't handle reading such high volume filing systems (Sure I read that somewhere) and it's Samsung fault because they did purposely remove certain drivers for USB host capabilities originally the Samsung Galaxy Note 3 was not only able to use USB mouse keyboard flash drive and hard drive but it was also able to use a USB to ethernet converter plugged into the OTG cable allowing you to plug your phone directly into your modem or router for lightning fast data after a while Samsung found it non profitable for them and remove the drivers and capability
Hi guys... Somebody can help me get through with this issue
Yup I also have to raise this compatibility issues of Android to different file formats. Just recently, I acquired a SATA SEAGATE 250G. I formatted it to FAT32. At first I've successfully made a back up to my overloaded files from my phone, that's why I decided to place those bulk files at the external drive. Time come that it just prompt mgs, YOUR EXTERNAL DRIVE IS DAMAGE, TRY TO REFORMAT IT". What happen?
I think Google should resolve this compatibility issue. I was commanded to shift back to Microsoft mobile if this issues won't be given a solution.
Anybody can help?
I have successfully used a 1.5 and 2TB Seagate Backup Plus formatted with exFat on a Samsung Galaxy S3, S5, S7 and Samsung Galaxy Tab Pro 12.1 no issues. Power consumption on a Samsung Galaxy Tab Pro 12.1 doubles watching a local file vs a file on external USB drive, just as an FYI. I decided to upgrade to 5TB Seagate external 2.5" portables and for some reason my Tab Pro nor my S7 seem to be able to access them. I tried to format the drives using the S7's drive format feature to no avail. Has anyone else come up against this limitation and found a solution. I am thinking perhaps I need to get a self powered NAS access point to resolve the issue.
cinemacritic
