Extremely Hot Battery temp.
Raiderspy1
20
Ever since I one click rooted (keeping RFS), my battery temp gets exceptionaly hot. No matter how I use it, it gets hot. Yesterday I talked on it for aprox. 30 minutes (I could feel it getting warm). When I hungup I checked the temp, it said 108 degrees. I turned it off immediately. Itnever got this hot before. Any suggestions?
I would download SystemPannel. This app will tell you what speed your processor is running and how much of it is being used, or the load on the processor.
I have seen some apps on my unit that get hung up and cause it to run hot and kill the battery. use that to see what app might be causing the problem.
Since your phone is rooted, you may want to check out SetCPU(There's the donate version on the market, and the full version free over at XDA). You can enable a profile to lower the CPU when it reaches a certain temperature. Even when my phone is clocked at 600Mhz, it still performs well.
bohanvo2
