Facebook problem on mobile data
Pozdrav druze.. Nemam LG, nego Samsung, ali dosta ljudi iz mog okruzenja je odradilo to na njihovim telefonima koji su razni.. Ako ne mozes da ga izbrises, ti izbrisi sve APN-ove i napravi nov, ali da se podudara sa trenutnim:
APN - Access Point Name: - [isto stavljas kao sto je trenutno]
Login - Username: - [isto stavljas kao sto je trenutno]
Password: [isto stavljas kao sto je trenutno]
Proxy: [ostavljas prazno]
MCC: [isto stavljas kao sto je trenutno]
MNC: [isto stavljas kao sto je trenutno]
Nadam se da ce tako uspeti. Pozdrav i javi sta si uradio..
Here is on English for all who have LG G-series.
Try deleting all APNs, create a single APN to match the correct settings without the proxy.
Internet Setting:-
APN - Access Point Name: [same as now]
Login - Username: [same as now]
Password: [same as now]
Proxy: [leave blank]
MCC: [same as now]
MNC: [same as now]
Finally solved, i got new parametres from my provider, now proxy are NOT set, and i am able to tap on it if want to change. App is on, again :)
I have the same problem. I use straight talk with a AT&T phone. So I have specific settings for my data to work. If I change the ports and proxy nothing works. It worked fine until a few days ago. It's really annoying.
Do you happen to have a Samsung Galaxy S5 Active? Because I am in the same situation and I was wondering if you were able to fix this issue?!
Hi Everyone :)
I am having this annoying problem going on with my G4 (H815T). I am using 1GB mobile data on a du SIM, all applications and web browsing work except facebook. The facebook application only seems to work on wifi and it will not connect if mobile data is on (regardless of 2G 3G 4G). I put the SIM on my older G2 phone to check whether its carrier related but it works perfectly there. Its only seldom when it works just for a bit then it wont.
Things tried:
- Uninstalling reinstalling app
- Updating app and phone
- Clearing data, cache, system cache
- Switching off phone, removing SIM and battery for 30 seconds and then reinserting
- Virus check
If I am logged in, it will not work, and if I am not logged in, I get this error written when I try to login:
"Sorry, unable to login to Facebook. Please check your network connection or try again later. (HttpNetworkException: proxy HTTP status 400)"
Any help please?
Are you running marshmallow?
Hey, if there something in proxy setting that you aren't set - change your Facebook (and other) passwords quickly! Very quickly! And not from phone. Only from computer. Somebody already have your login/password so if you don't want to lose your account do it now.
I tried that, but on my lg g3 i dont have settings as you called above, just apn settings automaticaly set from my network operator. I cant delete theme (or clear), but you were right, they are set to some port. I did the acces point reset to default, but still cant login to facebook app :( anybody else tried this method? Thanks anyway for giving a shot..
Hey there am LG G3 user too and I had the same problem
when you go to APN network settings, you tap an icon on the top right corner of your phone and select SET TO DEFAULT
tried and worked 100%
Hi Everyone :)
Things tried:
- Virus check
Any help please?
Hi Friends,
this problem occur cause of corrupted facebook App.
for this solution , go Step by Step, to mobile setting ---then App--in app ---all, then find facebook and click on that,
next click on Force Stop, then do clear cache . ........after done all restart your phone.........and enjoy
have a grate day.
Okay guys so after really intense searching and implementing different trials, i found a solution which worked for me, I hope this would help all of you.
So you go into mobile data, then APN settings. Go into both the WAP and Internet APNs, and I noticed that there was a proxy and port set. I cleared both of them, and wola! it works! :D
I dont know whether it relates to the error shown by the facebook app upon login, but the error did mention the word "proxy" so I tried that out and worked. Clearing the proxy did not affect anything else, neither connections nor speed for other apps or browsing :D
Do try it out and check if it works!
wow.... man this worked like a charm
I got the same problem with my Galaxy S4 however all my proxy settings are already "Not set" so there is nothing to clear. I tried:
- Factory reset
- Facebook reinstall
- Clearing cache
- Resetting APN to default
The only way I can get FB and messenger to work is to take out my SIM card and then only use WiFi. As soon as I put the SIM card back in my messenger can no longer load photos and my Facebook can no longer load photos in posts. Chat heads also no longer work and I can't retrieve old messages.
If the SIM card is in I can't logout because then I won't be able to login to FB again until I take the SIM card out again.
Whhhaaaattt is going on??
Thanks bro it worked for my new note 7.
Before it was not loading videos when I was using mobile data. It works now after removing the proxy abd port.
Go to APN of ur mobile data & delete proxy & port ......restart ur mobile.....it will work definitely.
Sitole Reshid
