Facebook Wakelock Problem
I also noticed this since I installed the wake lock detector app. Got so annoyed because sync is off and refresh is set to manual. I also signed out and wifi is off most of the time. I became so annoyed that I decided to disable the app.
Usually by the time I wake up, clock is taking upto 30% of the battrry when I have an alarm set and about 40% is consumed by android os which I suppose is due calendar storage wakelock issue. The problem is if it were some downloaded apps causing wakelocks I could have uninstalled them but how do I deal with stock apps causing wakelocks
Do you have GPS on? Are you using Google now? Location services? If so turn all off.... they chew through the battery
deevencoo19
