fascinate shows up as cd rom
I think the problem stems from here:
https://github.com/sirgatez/Android...ob/master/drivers/usb/gadget/f_mass_storage.c
Im just not sure if I am smart enough to fix it.
#define FEATURE_DEVICE_AS_CDROM_DEVICE_FOR_DRIVER/*-------------------------------------------------------------------------*/#ifdef FEATURE_DEVICE_AS_CDROM_DEVICE_FOR_DRIVER/* SCSI device types */#define TYPE_DISK 0x00#define TYPE_CDROM 0x05
why is this even in there. why would the phone ever need to show up as a cd rom?
we have faith in you. i certianly have more faith in you and the other indie devs than i do sansungs, that for sure.
I *believe* its in there for the verizon iso that pops up on their phones, these days. Im going to try and compare it to my HTC kernel source (it doesnt have this problem) and see if I can make heads or tails of it.
First attempt:
Failed to compile.
Second attempt:
I broke mass storage, and made Linux see my device as two storage cards + a cd rom drive, LOL.
Third attempt:
Successfully cleared out code, which in turn makes it a PERMANENT detection as a CD ROM drive.
Still trying.
Reactions: jbr05ki
First attempt:
Failed to compile.
Second attempt:
Third attempt:
Still trying.
sounds like you are making progress.
For anyone interested in a bit more about the phone's virtual cd-rom, sir gatez over on XDA provided me with this:
It is determined from reading nvram settings if the function should be turned on or not. By making 2 simple changes you can force it on or off. My patch below does not edit nvram it simple returns off where it should return on. NVRAM keeps the original value incase it is needed as some later point. Changing the tl_setting to 1 in get_tool_launcher_setting and returning 1 from is_tool_launcher_enabled will force the driver to load. You can change the location of the iso file in:
Eclair-2.6.29.6/drivers/usb/gadget/f_mass_storage.c
Line: 1454: static int do_inquiry_cdrom(struct fsg_dev *fsg, struct fsg_buffhd *bh)
if(is_tool_launcher_enabled())
ret = open_backing_file(fsg, fsg->curlun, "/etc/verizon_i500.iso"); //Edit this file name to your liking
#endif
Patch to disable CDROM driver in the OFF position, turning it on can disable other USB gadgets, bad kernel hacking will have your SDcard show up as an invalidly formated CDROM device if you plug it up with this on, be careful, backup your stuffs if you decide to experiment as you never know!!!:
Yes I could probably just patch one of the below functions but I like to be safe, as the NVRAM setting CAN be changed by the phone's system OS. So patching both ensures that if it does change, that it continues to return false that the driver should be disabled.
Eclair-2.6.29.6/drivers/usb/gadget/fsa9480_i2c.c
Line 2157: Function int get_tool_launcher_setting(void)
DEBUG_TL("reading tool launcher setting. TL: %d \n", tl_setting);
+tl_setting = 0; //This tells the tool launcher that the setting is off
set_tool_launcher_setting_state(tl_setting);
Line 2191: int is_tool_launcher_enabled(void)
+return 0; //This tells functions that the driver is disabled
if(get_tool_launcher_setting() > 0)
And yes, it is for the verizon .iso
I have the same thing with the AT&T Captivate
All I had done was followed this: Captivate JI6 kernel with "2e recovery" enabled - xda-developers
So as to roll back my 3e recovery to 2e so to be able to root (so it doesn't verify the update.zip). I used Odin3 and flashed the kernel.. If nothing else, I think i might try to flash the kernel. Anyone know where I can find the FROYO.UCKB1 kernel.
Here is also my post on xda:
[Q] Internal System Memory is showing up as a CD-ROM drive in windows 7 - xda-developers
mine shows up as a cd; the cd driver it keeps installing (if it helps) is:
Android UMS CD-ROM USB Device
AND
CDOZMV 4167 CLERKX2B SCSI CdRom Device
The second appears to no bring results on Google, but the first does.. I'll have to look into that.
Anyway I hope I/we can figure out what the heck is going wrong.
AND
Not giving you a blow off, but you might have better luck in the Captivate forum. I know the Fassy and the captivate are cousins, but I was reading you're post and was wondering what the heck you were talking about..lol
Then again, maybe someone does know in here, but you chances are better there
Anybody know how i could change the iso? Not delete it but possible change the iso file so it autoboots something different?
srabon
