Finally, Gingerbread for All DInc Owners! Part 2! Update's avail!
I did that. I followed your instructions except I used the .2 to .3 update instead of the froyo to gingerbread.
Sent from my ADR6300 using Tapatalk
Re: Finally, Gingerbread for All DInc Owners! Part 2! Update's av
The 2.3.4 OTA was waiting for me to install this morning.
Muddy - You nailed it.... Right file, just figuring out the correct steps.... Nothing is ever easy...
These seem to be the wrong links no. My phone thinks it's an EVO with 4.3 inch screen and sprint in the market not verizon? How do I fix this now any help is aprreciated.
I received the OTA update this morning. When it came back up, it didn't recognize any of my SD card apps. I'd powered the device off and back on several times and the issue persisted.
When I arrived at work I plugged it into the charger and shortly thereafter, the phone rebooted itself automatically. When it came back up, all my SD card apps were back.
Mine did the samething, but after then showed up, I rebooted again and now won't recognize any of my SD card apps again. :mad:
EDIT: Unmounting and mounting the SD card made them show up again...I hope I don't have to do this everytime I reboot... :-\
I had the OTA waiting for me this morning too, but I haven't installed it yet. I want to wait a bit and get my SD card backed up and see what other issues others have with the update.
Looks like I'm updating my wife's tonight.
OK, tl;dr
I rooted her Inc. Will it still get pushed to her? Stock rom.
Can you use unrevoked to re-root after the OTA?
Am I missing something here? I installed yesterday from the link in this thread and it says I am running 2.3.4 but I really don't see much of a difference. It boots a little faster but other than that I don't notice any differences. Did I do something wrong?
the clock animation is a bit different, check in about phone, and hardware section see if anything is different there, otherwise a few subtle changes nothing crazy.
I guess I was hoping for something a little more drastic :-) In any case, does anyone have any news about whether or not this will be able to be rooted at some point in the near future?
OK, tl;dr
If you are rooted there is a rooted version in the root section. If you install the OTA on a rooted phone you may screw up your phone or loose root and have to wipe it and re root the phone to get root back.
Reactions: BSG75
Thanks for your help. I'm having major issues. This is beyond ridiculous. Still same problem, but when I connect my phone to the computer is shows the file in the root directory. When I look on the phone in the oi file manager it's not there. When I run bootloader I still get the no image message. UGH
I'm having the exact same issues... non-rooted trying to update from .2 to .3
Let me know if you come up with a solution.
check the file name, i know its something simple but check if its update.zip the name of the file and then go into hboot and select update from there
Still haven't received the GB update
Thanks Dark. I've checked the file name, FAT32 on the SD card, I've gotten the .2 to .3 file (6.7mb)
I get the error message that everyone trying to do the update has gotten. I figure it's a headspace and timing issue here, just stumped atm.
I wish I could. I know what I'm doing since I had no trouble installing .2. I even followed most of the instructions including formatting the sd card which took a long time. I do see that the file is in the right place using oi file manager and it is update.zip (not update.zip.zip) I just hope that when the ota update is available that it sees that I have .2 and lets me update to .3. If it just looks to see if I have gingerbread I guess I'm screwed. I'm having some issues with .2 so I hope I can update. The biggest one is trying to call people from my car with bluetooth. It never gets the name right and calls people in my phone book that I haven't spoken to in years. Awkward
Notified today of a system update on HTC Droid Incredible.
The phone is continually giving me "android.proces.acore has stopped unexpectedly." messages. It seems to be related to backup assistant I am also all of a sudden out of phone storage room. Contacts will not load.
According to HTC technical "assistance" I have to do a factory reset and reinstall all of my apps.:(
Any suggestions before the nuclear opton?
You are using the wrong download. Use this one:
And the ota dl link to go from froyo to gingerbread!
http://android.clients.google.com/p..._WWE_4.06.605.3-3.26.605.1_release_210690.zip
The MD5 I got is: dcba30a164327c4f6903abf0222c5e9a
And check this post:
http://forums.androidcentral.com/verizon-droid-incredible/116534-ota-gingerbread.html#post1222770
Sorry man - They try to make the upgrade as painless as possible, but it does not always work out.
Try doing the backup steps in this post before you reset if you can:
http://forums.androidcentral.com/in...id-incredible-gingerbread-ota.html#post980677
hi guys! noob question O:-)
Has anyone running the leaked RUU (4.06.605.02) got the update notification to install the updated one?
sshkjgh7788
