I was (and still am) Stock. Haven't been brave enough to root or build ROMs yet... Was more comfortable with the xda kitchen for Windows....Rjh....were you stock or rooted?
Personally, I think it is a VZW marketing strategy... But is probably related to bandwidth and network load...why does it take so long for the ota to hit phones?
Looks like I've had some success....
Took out the SD Card. Copied all file to my PC. Reformatted FAT32. Put all files back. Renamed the suggested file (Froyo to GB) from 6f37e6f6b9ab.OTA_Incredible_C_Gingerbread_S_VERIZON_WWE_4.06.605.3-3.26.605.1_release_210690.zip to update
I did not include the zip extension because Win7 automatically attaches the extension (I think I checked the properties/details and it appeared as update.zip.zip - removing the .zip appeared to address my problem).
Right now the DInc is green arrows in a circle and a progress bar is slowly creeping towards complete...![]()
Muddy - You nailed it.... Right file, just figuring out the correct steps.... Nothing is ever easy...Sorry guys. I really thought I had something. From the way its looking it might not be so... The path seemed legit and the size and everything are matching up to what I've read.
Hoping someone with more experience can tell me what I've found if its not the update.
Sent from my ADR6300 using Tapatalk
OK - My steps to success:
- Power down the Dinc
- Remove the SD Card
- Copy SD contents to PC
- Format SD Card FAT32
- Copy files / directories back to SD card
- Download the 6f37e6f6b9ab.OTA_Incredible_C_Gingerbread_S_VERIZON_WWE_4.06.605.3-3.26.605.1_release_210690.zip file to your pc
- In Windows, F2 the file (rename) to update
- Copy the file to the root directory of the SD card
- Eject the SD card from the PC and reinstall in DInc
- Power and down volume buttons to boot to bootloader
- Power button to hload (I think that was the choice)
- Wait
Dinc reports:
2.3.4
2.15.10.07.07
2.6.35-13-g55a06e5
Build 4.06.605.3 CL140944 release-keys
followed these directions update went fine but lost a good amount of my apps.
Does anyone know how to switch between vibrate, silent and the selected ringtone? I used to hold down the power button, but that is not working now.
Yeah, I'm wondering the same thing. Odd that they would change something like that.
Still can't get this to work. Going from .2 to .3 downloading the correct link. Change name to update and put on root of SD. Says no image found and returns to the hboot screen.
