Paul Bledsoe
Active member
- May 8, 2013
- 40
- 100
- 33
Just got and installed the update on Unlocked Tmobile S24U in MS.
Easier file copying and moving It's easier than ever to find the right folder when copuing or moving files in My files. You can now choose the destination folder in a pop-up window so you can easily return the original folder when you're finished
Create file shortcuts on the Home scree Get faster access to the files uou use most. Touch and hold any file in Mụ files, then use your other hand to navigate to the Home screen Drop the file anywhere on your Home screen to create a shortcut to the file.
There have been a couple of sources that have revealed that the update will say One UI 6.1 & not 6.1.1 like on tablets and foldable devices.Downloaded the update this morning on TMO unlocked S24 in Southeastern USA.
I don't understand how/why some are posting the downloaded is One UI 6.1.1 when the update is clearly still One UI 6.1, Security Patch August 1, 2024.
What am I missing?
I still think they should have called it 6.2 and be done with it.There have been a couple of sources that have revealed that the update will say One UI 6.1 & not 6.1.1 like on tablets and foldable devices.
(@mustang7757 posted a link to an article in post #6 above)
The update is to One UI, but leaving the version the same doesn't make sense to me. But it's still August security patch.
You're not missing anything, they realeased the UI update but not the security patch.
They keep us guessing!
Yeah definitely be less confusingI still think they should have called it 6.2 and be done with it.
Here you go. I took a screenshot before it finished downloading.What does this bring?
Your not missing anything, i rolled back to 6.1 and disabled both software update apki have S24U with T-mobile in san francisco and i am still on One UI 6.1
oh? is there any particular reason you wish to share with us??Your not missing anything, i rolled back to 6.1 and disabled both software update apk
Well first off they removed a few features and Samsung will add them on OneUI 7.0 , plus there's a special app that stop working on 6.1.1 called Hex , That's why i rolled back there nothing that impressed me at all, So I'll wait for OneUI 7.0oh? is there any particular reason you wish to share with us??
members who already installed 6.1.1 please provide pros and con for sharingWell first off they removed a few features and Samsung will add them on OneUI 7.0 , plus there's a special app that stop working on 6.1.1 called Hex , That's why i rolled back there nothing that impressed me at all, So I'll wait for OneUI 7.0
Wrong, The S24, S22 ,S23 lines do say 6.1 and will be labeled that way even tho it's OneUI 6.1.1You have an S24U with an installed update labeled 6.1.1? Only foldable get 6.1 1. The non-foldable version is 6.1.![]()
