[FIX FOR] Netflix "syncing" issue
I take no credit for this and found it looking around xda site but these versions of Netflix disables market update checks I tested it and it worked.
Side note I had to uninstall the version of Netflix I had on my phone and only tested 2.2 and it worked with NO UPDATE SCREEN. Follow the link below.
http://forum.xda-developers.com/showpost.php?p=15841797&postcount=2
Dropbox link inactive again =(
is this thread dead? The fix link is broke... I just got an optimus S for my daughter...tried Netflix. It was having this syncing issue (and also not showing the video). I figured I would try this fix of installing an older version of the app, but the link is broke. Can original author please fix link in the first post? Thanks!
If u give me a few ill make a dropbox account and put the new file there
Original author is lazy. Aka never gets time off from work. ;)
is definitely working a lot better, but there is a green bar at the top... I saw some posts about that. I will have to figure that green bar out, then we're golden. Getting close!
Does anyone know how to fix the color issue and green line I'm running optirom
thanks so much for the help so far. Sync issue is definitely fixed. However, any Idea about how to deal with this green bar issue?
The only fix for the green bar is to use a cm7 rom.
Thank you, this Netflix app's sound and video is in sync. The coloring is a bit off though. Win some, lose some?
I want to truly thank you. After trying several apks, the most recent post fixed this for me. CM7 on MyTouch Slide 3G. MERRY CHRISTMAS !!
gulkhile
