So I love the Samsung charger but it has one giant flaw. The base sucks and the phone is hard to place and easily falls off. So I got my wood file, some kydex I had lying around, ground down the bottom just enough to be able to glue it. (be carful to not grind to much or mess up the backrest) cut out a piece that was slightly longer and wider than the phone. Be sure to test it before you glue it.
I used basic super glue in case I needed to remove it, which I did. My cord went bad in between unplugging it and plugging it back it. I thought it was not connecting to the charger. Grrr.
Now it is super stable and doesn't fall off when you look at it to hard. The only other option I would suggest is to put a lip on it to keep it from sliding out if you turn the screen off or raise the volume.
I could make it look better but it sits next to my bed and only look at it when I get up and when I go to sleep
