flash player problems
brerspidur
Has anyone else had any problems after installing the flashplayer apk? I previously installed this on my Note 2, and had no issues with the stock browser. With the Note 3, even after installing the apk, I get "Error Loading Player: No Playable Sources Found" on the stock browser and on chrome, but it works fine on Firefox. Has anyone had any luck using flash in the stock broswer?
Thanks
Hi. I've had the same issue. Flash worked on my Note 2 stock browser but not my Note 3. I read somewhere that the Note 3 stock browser does not support flash. You'll have to switch to Firefox, Boat, or some other browser for flash viewing.
sent from my Note 3
I just read in another thread that a restart will allow flash play on the Note 3 stock browser. I just tried this myself, and flash is now playing. Give it a try.
sent from my Note 3
I use Puffin. It is lightning fast and it has flash built into it.
Sent from my SM-N900V using AC Forums mobile app
Marlene
