flashing Incredibly Re-Engineered 2.3, INSTALLATION ABORTED, Help
Try this: go to this thread
xda-developers - View Single Post - [ROM] Warm Z TwoPointTwo [RLS1] [2/23/2011] Re-Engineered Nightlies [4/23/11]
See where it says "attached file"...download that and place it on the root of the sd card. What this is going to do is give you Clockwork 2.5xx temporarily...as soon as you reboot out of CWM it will revert back to 3.008 or whatever your last updated version was.
So, you got CWM 2.5 on your root, AND the ROM you want to flash on the root, boot into CWM and flash the CWM 2.5xx via "install zip from SD". When its done you should go from CWM with orange typeface to CWM with the green typeface. Now, don't reboot yet. Do all three of your data wipes now. Then do the standard install from SD and flash the ROM you want...after it's done THEN reboot and let it load up, you should be good to go from there.
Remember, put BOTH the ROM and the CWM 2.5 on the root and don't let it reboot until after the ROM has flashed.
johan mayhew
