- Jun 20, 2010
- 249
- 20
- 0
Wondering if anyone can help me out here,
I am trying to flash Incredibly Re-Engineered 2.3.
I have encountered a big issue.
As usual flashed latest clockwork, booted in clockwork, wipe data, wipe cache partition, wipe dalvik cache, went to choose zip from sd card, nav to the zipped up rom.
It started to install then stopped saying this,
amend scripting (update-script) is no longer supported.
amend script was deprecated by google in android 1.5
it was necessary to remove it when upgrading to the clockworkmod 3.0 gingerbread based recovery.
please switch to edify scripting (updater-script and update-binary) to create working update zip packages.
Installation aborted
What the hell is that and how do I fix this, I am now stuck in clockwork recovery.
I have flashed tons of roms, and this has never happened, It must have something to do with the latest clockwork recovery update
Thanks
Ken
Thanks
Ken
