Forget waiting for OTA to work. Flash ICS using the ODIN method!
Reactions: ccm435
Re: Forget waiting for OTA to work. Flash ICS using the ODIN met
I know it was just posted but please, anyone that gives this a try, please let us know how it went.
I doubt it needs root by hopefully we will find out soon.
Another quick question, does this work for the Verizon 10.1 4G Lte tablet.
Trust me. It will work. You can even use Odin to flash a stock ROM even if you are rooted running a completely custom ROM. Done it myself.
Sent from my GT-N7000 using Android Central Forums
Probably not. I believe it's wifi only
This is for the GT-P7510 Wifi US (Maybe UK) models. Works for both 16, and 32 gb models. It will also flash you from any version of any software you are currently on to the current US ICS version, but root is also not needed.
-cm-
