Forgot my PIN lockscreen
Hi My pin was changed on my Samsung Galaxy s5. I have registered my device with Android central but for some reason it comes up with the message that there are "no active devices".Please help. Thanks in advance Fran
Hi I tried to set up my registration but wont accept my Australian zip code...therefore I cannot proceed with my registration. Pls help...thanks
Okay, so I have read through the entire thread and I am STILL locked out.
I have a Nexus 5, with a pin number lock (not pattern).
1)I cannot send my pin to my gmail account through my phone (this seems to only apply for pattern locks)
2) I have tried using the android device manager and setting a lock, by inserting a new password. This seems to have worked for many people,
but even when I put the new password in on the device manager, my phone still persists on saying "you have incorrectly typed your pin x number of times".
I don't want to factory reset!
Any other ideas of how to get in?!
Dave....can u help me in resetting my password without factory rest......Your post is good but wen I am searching for location it is saying that your device location acces is turned off....so its not showing my location..so can u please help me?? Can't reset because i have some important files in my phone memo...Dave please help
i have entered almost 130 times.but still it is showing PLEASE WAIT FOR 30Secs......Ap per your post it is not showing any pop up....can u please help me in this issue....
I used my gmail password fo the first try and later use another password and the system shows "locked by android device manager". when I entered the new password it showed "wrong password" again.
I forgot my pin lockscreen and my Samsung galaxy note edge sm-N915T is locked. please help me unlock it. the internet is not even activated.
i forget my screen lock i cann't open my android phone
My phone is LG and i forgot my screen lock what should i do. please help me i cannot use my phone:(.
it doesnt let me reset the password on the lock one because it says i already have a password on the phone anyways... which is rediculous because thats the one i dont know!!!! :( aaahhhh helppppp
I forgot my password on my ADTAB 7 LITE and bingo-the perfect answer after having watched hours of mumbling morons on U-tube!!!!
regards
Omg!! I was just starting up my laptop for my google+ e-mail and then i just remembered my pin code.....how annoying is that!! Good luck remembering your pin code guys!!
No, no, no! If you hit lock it lets you choose a new password. But then it says, no need to change password because is already locked. Catch 22.
I wrote screenlock pin code (asdfgh), this morning when I turned on the cell phone is no longer operate this pin, each time a "wrong password"!
Android Device Manager, I can not remove this shĺt, because I can not turn on wifi!
Samsung S3 Neo GT-I9301I
OS: 4.4.2 NO-ROOT!!!
PLEASE WORKING SOLUTION OR HARD FIX!!!!!!!
THANKS!
but it says google has already detected password lock so i don't need to apply new password.
This has been the best advice out of anything else I read. It completely worked! No factory reset required and it is so easy
did it work for u? how?
kctraci1
