Forgot my PIN lockscreen
THIS IS WHAT WORKS!!! I have a google nexus 7 and it worked. i locked the device and could reset my pin to unlock the tablet. THANK YOU!
"I had the same issue but all you need to do is Login to your google account on https://www.google.com/android/devicemanager
then it will automatically find your phone. You have to chose the option "LOCK" it will ask you to type in a paasword that will automatically show on your screen there you have it and your password will be reset witout you having to do factory reset"
regarding pin lockscreen, i am trying to install "find my phone" on galaxy s3 but from the pc message is coming "congratulation find my phone will be install soon" as i have install "find my phone" on my other galaxy duos. now i want to install on galaxy s3 which is locked. Please explain how can i install,
If you have an sd card in your device (most of us do).....export all your pics...vids..etc...into your sd card. Theres different ways to do that depending on what device you have. Power down and remove sd card. Power up an execute the factory reset. That procedure varies also. Power down and reinstall sd card. Import data or leave it on the card. Device will access data either way. GOOD LUCK
My samsung s5 was stolen, it had a pin number. If you have forgotten your pin,sorry, get a new phone.
The phone will not unlock.
Please help! My phone is screen-pin locked, in Google device manager there no 'Lock' button. Also I tried many combination to make hard-reset on my Xperia E-dual, but phone every time booted as usual way and don't show emergency boot. What to do?
Dear sir ..
Pls i gave a friend of mine my phone wanted to check livescores on it . and its was using a wrong pattern , but now i cant assess my screen phone now , samsung galaxy duos .
Pls i cant receive call or do anything on my phone . Pls i need an urgent reply
Regards
Adekunle kazeem
Like someone mentioned earlier, this is one of the very few solutions found online that actually worked, easily and seamlessly. Thanks a lot Dave Jr. for sharing this!!! A big relief that the data and settings wont be lost.
It worked!! I unlocked my phone without having to do a factory reset because of your post. I searched for solutions for 2 hours, once I found this it was a 60 second fix! Thank you!
I had the same issue but all you need to do is Login to your google account on EDITED DUE TO NEW USER RESTRICTIONS
then it will automatically find your phone. You have to chose the option "LOCK" it will ask you to type in a paasword that will automatically show on your screen:) there you have it and your password will be reset witout you having to do factory reset
Thank you! Thank you! Thank you!
I'm still learning my way around Android, and my other half is even newer than I am, he locked himself out of his Tablet last night, and I was going BaNaNaS! trying to figure out how to unlock it without a factory reset. Your post here has taken me hours upon hours to come across, but IMMEDIATELY (yes, I'm shouting it atop hills on high) provided results, and the exact results I was looking for. You're a Gods-Send!
left nexus on plane
so when got it back decided to put a pin on it. . DId that and now if I enter pin the nexus will not open at all. just keeps the numbers there. no movement. How do it get it to start?
I tried entering the wrong pin etc. nothing changes. and holding down the turn on button. Now I can't even get to power off.
Just plug your phone into your computer and copy important files, then install a factory image.
Posted via the Android Central App on my Nexus 4
kctraci1
