I'm liking it so far. No huge noticeable difference. At least nothing glaring
Sent from my Galaxy Nexus by way of Tapatalk
I dig your Nav buttons
They are courtesy of DroidTh3ory. Most of the roms descended from his work have them.
Ok I was wondering if anyone else is having issues at all like this.
I am having issues with my Droid and not sure what is going on and what the problems are.
I do not know how to yet to troubleshoot and diagnose the phone yet so if you know please let me know as well.
The apps do not respond when I select them and it is not just one. I have been clicking on Market, Barcode Scanner, ASTRO, Calendar, Settings and nothing will open up at all. They just get highlighted and that is it. After awhile the apps will just open or if I taskill everything they will open up.
So I am not sure what the issue is at all but this is not the first time it has happened. Am I running out of resources, memory or what? Just dont know what is causing this issue at all.
Any help would be greatly appreciated.
It's conceivable it could do some damage long term, but at the same time who knows? I just say play it safe and if you even need to over clock, the 1344 step should be just fine.Hey just downloaded tonight's r192 and. Noticed the sweet over clock, my question is it safe to juice our phones that high? I know it will be an issue when it comes to battery life,but just wanna know if it is safe.
1. Every Rom comes with a Kernel the devs like, you are free to change it out for whatever you prefer, but yes when you first flash flash the ROM it will give you its kernel.I have been flashing the CM9 nightlies, really been enjoying that on my CDMA Verizon Nexus (ruunin CM9 0621 build..now thinking it's time to start kernel flashing. I have purchased the Franco.Kernel updater app. I have a few questions that I can't find the answer to. Thanks in advance, for any help!
1. When flashing CM9 or any rom for that matter, will that automatically overwrite the existing installed kernel (say if Franco was installed)?
2. is there a way or reason to backup an existing kernel, before upgrading?
3. Milestone 4 or r192 ?loaded question huh!
4. Are there compatibility concerns between roms and kernels, or as long as you are on a 4.04 rom build, running a kernel made for your phone, your good?
5. Thoughts on CM9 and Franco builds?
6. 384 or 512? Not sure what that impacts?
I was trying to find a FAQ for the Franco App/kernels, URLs?
Thanks again for any guidance, links!
Thanks 2defmouze! I appreciate the answers!
I have flashed r192/384, with CM 0622 and placebo or not, sure seems to be good on battery, deep sleep and performance in my short 6 hours of testing. Still playing with settings, using Wheatley and just a one tick up on max cpu speed.
Will monitor over the weekend . Thanks again!
Tom
Digitally transmitted with Tapatalk 2 on my VZW Galaxy Nexus running a CM9 nightly and Franco r192
This is with the 1651 mhz
Sent from my GT-I9300 using Android Central Forums
What governor?
Can someone please explain the Franco Power Modes to me?
