[FullHDMI] Official FullHDMI discussion
I neck deep in testing but will be posting full benches today. Oh, what kernel are you running and what rom?
HTC EVO 4G Hardware 0002 NovaTech panel
Software: 3.70.651.1
Rom: AvaFroyo Z3
Kernel: SBC-net-4.2.2-less-havs-v7-FullHDMI
Recovery: ClockworkMod 3.0.0.5
HBoot: 0.76.2000
Radio: 2.15.00.11.19
WiMAX: 27167_R01
PRI: 1.77_003
NV: 1.77_003
PRL: 60674
MicroSDHC: SanDisk 16GB Class 2
Battery: 2400mAh Li-ion
Not that $3.00 is gonna kill me, but I was of the impression that initial donors would not have to pay for the program. My donation was substantially more than the Market price for development purposes. Any insight?
What is the recommended 1-2-3 steps for plugging in, e.g. mini to phone, HDMI to set, start program, or something different? I don't use any specific sequence but I'm still trying to work out the previously posted issue with a Sony set. (Sort of like the failed Apollo 13 mission huh)?
HDMI to set, mini to phone, set TV to proper input, wait for phone to recognize HDMI, start FullHDMI.
I am refunding donators, please send me an email if you were not on the announcement email earlier.
I sent the market announcement to testers mainly to make sure all the overhead from market and licensing did not break anything.
I will be making an update today or tomorrow with 720p support, and releasing the latest kernel with the sources here on AC.
All this needs kernals doesn't need kernals, I'm a little confused. I just dove head first into buying the app (like I said I would) and I'm running rooted CM6 (since I accidently erased my stock ROM). So is there anyone that can give me a bottom line on whether it works on rooted CM6 with out anything having to be added such as kernals and what not. Just want to get some input before I go home and try the app out. Thanks!
if you do some light reading of the first post, or the market app description you'll see the app will work with ANY kernel, custom or stock, but some advanced features, such as full hardware mode support and higher fps will be available only if you flash the custom kernel (which is 2 minutes of work by the way)
Reactions: customblackberry
Which kernel are you going with?
i downloaded the market version and it wont work. keeps saying service not running. i have a totally stock evo only a couple months old what am i doing wrong. i fallowed the steps that were posted earlier.
Lokifish I tried to review your test results - the abbreviations and amount of data is a bit confusing. What are those stock/stock, stock/net, vael/net headers?
Can anyone please post fps results of the market version for SBC-net-4.2.2-less-havs-v7-FullHDMI kernel?
are you even rooted? do you have superuser installed and did you allow the app root access?
Lokifish what are those stock/stock, stock/net, vial/net headers in your test results?
Can anyone post fps2d results of the market version with SBC-net-4.2.2-less-havs-v7-FullHDMI kernel?
Stock/stock is stock rooted rom with the modified stock kernel
stock/net is stock rooted rom with the modified Netarchy kernel
Vael/net is Vaelpak 3.2 rom with the modified Netarchy kernel
I tend not to do fps2d anymore as I find an3dbench a better gauge of performance. I can run a quick fps2d test for you but at what res and with supercharge on or off.
Has anybody noticed posts changing posters and other wacky stuff? I've rebooted twice and it's the same.
wobblefix
