[FullHDMI] Official FullHDMI discussion
update your kernel too - latest netarchy 4.3.4 CFS kernels tree has been reported to work fine with FullHDMI
Benchmarks and analysis updated. Net 4.3.4 HDMI is now the standard kernel for Sense (except for Stock Rooted/ Stock Kernel). The TW AOSP HDMI kernel is now the standard for CM7. Baseline data has been added as well as V-Sync OFF and 720P at the approval of both devs.
The fully updated chart represents @ 10hrs of benching and testing.
Wow nice work Loki. That chart is great but I have one question, which tests represent FullHDMI w/ the SBC kernel I have posted?
hey i dont know if anyone know about this but i used z4root and temp rooted my stock evo. now full hdmi works great only it wont stop service. any advice?
Can you download busybox from market (its free) and try again plz
do i need to be rooted to install busybox? i had to reboot to stop full hdmi and i have to temp root every time i reboot.
ok sorry for the jump around on kernels but i'm running:
netarchy-toastmod-4.3.4-cfs-havs-less-nosbc-universal-signed
i had been attempting to use 800x600 and did not get any video output like i did previously with original HDMI Kernel. 720x480, however, works quite well. not sure if it's just the kernel or my constant fiddling with it today.
I cannot seem to get the app to launch after this last update 1.03 from 1.01.
I keep getting the message "APP_ERROR" and then the red notification that says "ERROR STARTING SERVICE"
I updated busy box from 1.16 to 1.17.1 then to 1.18.3 but no dice.
I also updated to my kernel
from netarchy-toastmod-4.3.2-cfs-nosbc-havs-less-universal-signed
to netarchy-toastmod-4.3.4-cfs-havs-less-nosbc-universal-signed
Please note FullHDMI v1.01 used to work on busybox 1.16, netarchy4.3.2.
Any info would be appreciated.
"APP_ERROR" is from Google's Licensing service. Sometimes google caches the result for 3 hours, to get rid of it please go into your settings->applications->manage->FullHDMI->clear data.
Is this the same TV where 800x600 worked before?
Did that again right now, but nothing.
The APP_ERROR went away, but the ERROR STARTING SERVICE is still there.
Can you uninstall and redownload/install plz.
Not sure if it was busy box or the 4.3.4 kernel, but my wifi stopped working, would just sit there getting an ip address.
I restored from the nandroid (backed up before doing the busybox and updated kenel), back to original busybox 1.16, netarchy 4.3.2, Full HDMI 1.03 and wifi worked again.
I still could not get FullHDMI to start, but decided to turn off wifi since you said that the APP_ERROR was an authentication error, and then launched FullHDMI and the app started, but... it was not outputting a picture on any resolution.
I then did as you said and uninstalled and redownload and install, now everything is working.
Weird! I will try the updated kernel again WITHOUT busybox to see what actually broke my install. Will report back later.
Thanks for your help.
Hello all first I'm no programmer and I don't even play one on tv but I paid for the app and I'm waiting till the no root version comes out. but I saw this and found the z4root and although it says I'm rooted the full hdmi is still not working. I tried downloading busybox and still nothing. can anyone help?
COTSWOLDMARK
