Galaxy A5 2016 (SM-A510F) overheats and wifi stopped working!
Hello, from two weeks my 1 month old A5 is always very hot and the bluetooth and the wifi sopped working.
I have only installed snapchat, whatsapp, telegram, any.do, runtastic and lifesum. All from the official play store.
Anyone can help me?
Sorry for my bad english, I'm still learning. O:-)
Hi I have a Samsung A5 duos and the problem appeared after the first time I have used runtastic. Try to uninstall it and see if problem is there
I have an LG G3 with Lollipop 5.0.1 I am having the exact same issues as the fellow Droid lovers. My phone will be performing normal then out of nowhere the phone will start to heat up the battery life will decrease significantly and the Wi-Fi and the Bluetooth will not work anymore. I have not downloaded any new apps, I clear my cache regularly and I don't do anything that would involve me getting a virus.
Does anyone have any solutions to this problem yet. I am willing to Root the device if necessary I don't want to buy a new phone please let us know if anyone has found a solution.
This seemed to work for me, not sure if it will help you. My wifi would not turn back on after disabling it and the phone would use the battery quickly.
I ended up restarting the phone, it would crash during restart so I had to hold the power button for quite a long time (minutes) before it powered down.
I booted into safe mode (when the a5 logo comes up when rebooting I held the volume down button until it booted).
In safe mode I enabled and disabled the wifi several times and it seemed to always work.
I then restarted the phone and booted normally. The wifi could now be turned on and off reliably.
I'll keep testing, so far it has worked for over 5 hours...
Hi,
I have the same problems (Phone get very hot even if it is off, battery is always discharging too fast and the bluetooth and the wifi sopped working.)
I tried all solutions without success.
I want to try downgrade from Android 7 Nougat to marshmallow 6
Tfunz
