galaxy nexus hand time
sblantipodi, I'm betting the the CPU is underclocked. I believe the 4460 is capable of going up to 1.5 GHz.
Contradictions with the camera (5 instead of 8mps, not that it really matters) if the specs on the front page are correct. Then again, SUB-dawg might have been mistaken.
It also looks thick from that angle but then that's not a very good angle to judge the size of the phone. Just 13 and a half hours!
sincerely I belive to the specs seen in that advertisement more than what SUB-dawg saied.
If that will be the specs I'm quite sure that this phone will be abandoned by many users.
I would like to know how SUB-dawg got his leaks :rolleyes:
sincerely I belive to the specs seen in that advertisement more than waht SUB-dawg saied.
I wouldn't say many users. I'm sure it'll do quite well with the community given that it's a Nexus device. The draw to it is it's openness, direct updates, and even those specs are nothing to scoff at. I never understood why people are griping over .3Ghz (if you really want it that bad, I'm sure you'll be able to overclock it eventually). Remember, the showcase here is Ice Cream Sandwich...not necessarily the hardware.
As with the camera, as been said countless times, the megapixels don't matter. As long as the image sensor is improved and can be comparable to a digital camera, or at least close to it, then it'll be sufficient for most peoples needs I think.
If the latest cutting edge specs matter that much to you, then you should wait a couple of months and something else will be out that'll be better.
With cheap specs like that I really don't count on a good camera.
I know that specs isn't that much important for everyday use but why we should pay 600? for a phone that worth 300??
It is surely the 4460. TI lists the max clock speed for the 40 at 1Ghz. As for the camera, I'm confident that if they chose to put 5mp in it. It is for superior quality. Look at the original Canon eos 1d. It lacks half the megapixels as forays cameras but is superior in almost every aspect. Lots of sports photogs still use it. Anyway, I'm not worried at all yet. I will say, the photo does make it look like it could use a diet! I wish subdawg would comment on whether this looks like his device or not.
Reactions: Andrew Ruffolo
Megapixels do not the camera make! Sblanti, move on to a different phone. Seriously this one is not for you. Go find another forum to spread your negativity on.
Ahhh man this device is the holy grail of Android. Especially since it's on VERIZON!!!!!!!!!! I can't wait damn it!..... What more can we ask for? The best device in Android history mixed with the best carrier in the U.S!!!!!!! LTE is going to be soooo bad ass on this device.
I know that specs isn't that much important for everyday use but why we should pay 600€ for a phone that worth 300€?
If you discredit it before even seeing it, using it, or learning anything official about it, then why even bother posting here? Just move on to the next bridge to hide under.
...And welcome to my ignore list.
Or if Google was smart, it wouldn't be an exclusive......It's not a device that is going to move mass numbers to Verizon, like the iPhone did for AT&T......Google should drop it on all the carriers they can. Their release structure for their "Nexus" line is lacking.
I well know that megapixels do not make the camera but I know that they decided to use cheap specs and the camera will be cheap as the other specs.
Cheap specs??? What are you talking about?
Galaxy S2 is using a better CPU now with its revamped specs.
SGX540 is old by years and is a weak and slow gpu.
5mp camera means nothing but with the specs above I don't expect anything good.
in any case I'm really impatient to know what is the unbelivable features.
?You won?t believe what we managed to get done in this release."
I don't really trust this picture. Have a close look on the Samsung Galaxy SII LTE. It says 5 megs cam as far as I can see. But the picture on the Docomo page shows the SII LTE with 8 megs.
I'm not saying that I wouldn't be fine with 5 megs but I would like to see the CPU running with 1.5Ghz. ;-) So there's at least one error in the page. Why not a second? ;)
sincerely USB2 is also hard to belive.
Is anyone else afraid that this phone is going to be too big? Might as well put an iPad in my pocket. I'd think 4.3 or 4.5" would have been plenty. I was hoping the screen would have been more edge to edge to make the case size smaller. 13.6cm long is huge!
Reactions: Nirvana328
gulkhile
