Galaxy Note 3 - Case & Covers Thread
Re: Note 3 Case Thread.
Giving back to the community who helped me transition smoothly to Android after eight years of Blackberry(still miss the physical keyboard!), here are pictures of the UAG case:
-It adds significant heft to the phone and doubles its thickness.
-Correct me if I'm wrong, but our phones have three microphones but I can only pinpoint two openings in the case for two. If true, whether that affects calling sound quality remains to be heard.
-The protruding lip protecting the screen is adequate.
-There is slight bulging of the case around the volume rocker, but otherwise the case fits tightly and well and the buttons are responsive.
-It doesn't sit completely flat on a flat surface.
-The included screen shield is arched/bent in packaging: not sure whether it was intended to make installation easier or a packaging issue.
I considered the Spigen neo case but pictures of rubbed off painted plastic bumper and the fingerprint magnet of the back cover made me reconsider. UAG's plastics are injection-molded with stain color throughout, not painted.
Very Nice. Now, get that to me in a dark silver (gunmetal?) or black, and I'm all in.
Just ordered a neo hybrid case in satin silver
http://i.imgur.com/ncnUZIw.jpg
http://i.imgur.com/ugk0FZk.jpg
http://i.imgur.com/injlQoO.jpg
http://i.imgur.com/hfXyz2G.jpg
I'm jealous
Note 3 <Caesars>
My UAG case came today in Outland Orange. It is big and adds significant bulk to the phone. But it also provides a lot of protection I want for my back country adventures with the phone.
I wish it was a little grippier. The hex pattern on the edges is pretty grippy though. I left my Spigen screen protector on and haven't tried out the supplied screen sheet.
I don't have the bulging around the volume rocker the earlier poster mentioned.
I'm pretty happy with the fit of the case. I might get a slimmer case for in town use and keep this one for outdoor use. Need to spend some time with it and see how it goes.
I finally realized that these UAG cases remind me of Hummers. Its like a Hummer for your phone. I like it.
Yes, the third mic is on the lower right side near the Spen. You saying they covered that one? Can't tell from your pictures. I was really looking forward to getting one of these cases but I wonder if that will have a negative effect on noise cancellation or audio recording if the mic is covered.
EDIT, nevermind--I looked closer at your photo and the noise-cancelling mic is NOT covered. It's right there--that tiny hole next to the headphone jack.
I'm jealous
Note 3 <Caesars>
No need? It's a mass-produced good that's rather attainable.
Great review. Agreed on being bulky. I keep my phones for a long time as well(averaging four years) so hopefully this will keep it in tact.
Yes, in that rugged look which I'm not entirely sold on and many hate. I really want a minimalist solid aluminum bumper case but the issues with reception keep me at bay.
Yeah, I'm looking for this third microphone and cannot find it. I don't see any openings near the pen.
So that's the noise-cancelling mic, thanks for fighting my ignorance. Where is the third mic, then? Second mic is clearly right of the usb port in the picture.
In this image you can see the third mic on the side to the left of the Spen
Good eye, thanks for pointing it out to me. As the second pic shows, there is no cutout for that mic but there does seem to be a gap in the case that seals a small volume of space when the phone is in the case. I have forwarded this discussion to UAG.
Lower left in this view.
https://www.youtube.com/watch?v=WtdCb16SWTA&feature=youtube_gdata_player
By far the slimmest case for the phone. Even thinner than the SGP and Rearth.
The only problem (for me) with that case is that it leaves the top and bottom exposed. If you like this style case (tight fitting with partial top/bottom exposure) I would also suggest looking at the Bear Motion Premium Slim Back with "Sand" Texture. Similar form factor as the above, and arguably better grip that still doesn't stick to your pocket. The sand texture may rub off from the corners with time though (it appears to be sprayed or dipped on the surface).
PROS:
- Thin, doesn't add bulk (+2 mm thickness, +3 mm width, +1 mm length)
- Nice soft premium texture
- Looks great on the phone
- Still easy to use all buttons, access S Pen, etc.
CONS:
- Doesn't protect top or bottom, or area around side buttons
- Flush with camera (limited protection)
- Texture may not last forever
I love mine (and so does my wife), but I decided to try the Rearth Ringke (already shown earlier in this thread) for better top and bottom protection (and more protection around the buttons too).
PROS:
- Even thinner than Bear Motion, doesn't add bulk (+1 mm thickness, + 3 mm width, + 3 mm length)
- Raised lip around camera (better protection than Bear Motion, which is flush)
- Also looks great on the phone
CONS:
- Hard case surface with smooth matte texture (like Droid X?), but does show finger oils and is more slippery than Bear Motion sand texture
- Harder to use side buttons (just need to modify habit to press from below instead of directly from the side)
- The tops and bottoms are protected, but don't have a lip that curves over the chrome face bezel as much as the sides of the cover. The top and bottom of the case appear to be 0.5 mm shorter/lower than the sides, so top/bottom protection is still not perfect/complete.
^^ I like the Bear Motion but the fact that it doesn't protect the top or bottom is a deal breaker. Why, oh why do case manufacturers do this? Is there a functional or logical reason?
I got the Grey Spigen Bounce. So far so good. Has a good look and feel....buttons and S Pen are very easily accessible. Survived a couple drops so far....ocassionally I'm on the clumsy side
Sent from my stock/rooted MJ4 blazing fast beastly Galaxy Note 3
I tried to search on the web as well as the user's manual, and there's no information on that hole at all. One website said it's another noise-cancelling mic, so that means the Note 3 has two noise-cancelling mics, and one main mic for speaking?
I got my spigen slim armor yesterday and it has the 3 cutouts for the mics... I also have another case that doesn't have the cutout for the mic by the s pen and really didn't notice any difference as ppl could hear me fine...
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
On the right side corner of the phone down by the spen there is a hole what is it for? my tech 21 case has a cut out for it but my new uag case doesn't and if I have to send it back I'm gonna be so pissed waited almost a month to get this!
Guess I got my answer it's a mic ? Will this affect performance if the uag case does not have a cut out for it?
wobblefix
