Galaxy Note 8 Tempered glass screen protector
Are you happy with it?
I only put it on just now, had forgotten about it because I had gotten peed off with screen protectors and was just using the Note 8 naked, it seems ok for now, adhesive is quite strong, I had to lift it up twice to align and remove dust specks and it still sticks really good, I'm using a clear LK slim case with it and you can't really see there is a screen protector on it
Well it only lasted half a day, sensitivity on top of the screen was to reduced so ripped it off again, maybe I'm just to picky because I've used it naked for so long
I'm going to try the InvisShield True Fit TGP to replace the shattered Whitestone Dome Glass on my brother's Note 8. I just bought 2x Glass Protectors + 2x LOCA glue for close to $50USD including S&H. Definitely much cheaper than the Whitestone Dome glass. And it's supposed to have better adhesive properties (heard it was thicker than what Whitestone uses). Don't need the UV light as I have 2 of them. I'll see how this one goes. Heard it's a little shorter than the Whitestone allowing for a little better case compatibility. Will have to see once I get it in.
I am still holding out for a sensibly-priced protector that works for most buyers.
Anyone tried this tanaab glass screen note 8 got 5 star rating and cheap by comparison...
https://www.amazon.com/gp/aw/d/B075...ag=hawk-future-20&ascsubtag=UUacUvbUpU6150626
I have this one, it has been good. The edge is not perfect, but it is full adhesive and there is no sensitivity issues. The problem is, you cannot get it now and they never released one with perfect curve to the edges. I dropped my phone and cracked the protector and now I need another one. The only ones close to this are too expensive.
you can get lucky with a good install of some screen protectors but they all turn out shoite, make the effort to look after your device instead, much better user experience and you are not wasting your time and money
ruhidubey017
