A anon(3092520) Well-known member Mar 18, 2011 287 40 0 Dec 21, 2013 #1 I was wondering if anybody can put in in terms of a percentage as to how much battery life is affected by having power saving on vs off? Anybody ever conduct a test, or know of somebody that has?
y2whisper Trusted Member Apr 15, 2010 457 2 0 Dec 23, 2013 #2 I would just test it out if I were you. Mileage depends on usage so any tests come with a large grain of salt.
AxlMyk Well-known member Sep 12, 2012 1,217 0 0 Dec 23, 2013 #3 With this 4.3 update, I don't think it matters, much. My battery is being sucked by the Screen. It's brighter, and doesn't dim down as much as before.
iN8ter Banned Jan 23, 2012 960 5 0 Dec 26, 2013 #4 It works well. I use it when traveling. I keep haptic feedback on though. Sent from my SCH-I535 using Tapatalk
