Galaxy S5 case with wireless charging cover
Leonardo Sanchez2
4
Hi can I add that I'm currently using the otter box defender with my galaxy s5 with wireless charging back but you have to rig up the case a little bit and one thing to note it doesn't snap on but it works fine I had dropped my phone from high and it stays in place. What I did I took off the screen protector it has because it's thick and got one for the actual phone they thinner then I took off that little cloth that is in the back cover of the plastic one and put them together they don't snap but the silicone cover it comes with will do its job and hold them together just make sure the corners of the silicone one are snapped in place and there you have it you can't even tell the plastic cover are not snapped in
andej
