Galaxy s6 camera problem, normal?
  • Start date Start date
A
AC Question
Hello guys recently got galaxy s6 and am loving it !
The only issue am facing is the front camera lags while moving , especially in low light . In video it's normal no lag but in selfie it lags while moving
The weird thing is camera works perfectly fine with 3rd party app , even though colors are dull.
So guys tell me what should I do? Is the page in low light normal?
Hey, I think quite a bit of lag comes down to the beauty face function. If you try and reduce that to zero does it improve? you will find 3rd party apps faster and lag free as they won't have the beauty face feature enabled.
(OT)
I have already disabled the beauty face to 0
Still no luck. Everything is finready just when you take selfie in low light specially it lags .
What to do ? Is this a software problem?
Hey, welcome to AC :) It might be something that is rectified when Marshmallow comes out, but it might also be something that the camera isn't capable of doing in low light. You're definitely not alone in this issue though.
Yup many are having the same problem.
And it works perfectly fine as soon as you add some effect only normal mode lags.
Worried cozy this is my first android phone
S6 owners please reply !
I am worried that is it a problem with me only?
In wide mode it's lag free only in normal mode my front camera lag and that too in low light.
KidColoringPage
