Galaxy S6 : Post Pictures Of Your Home Screen(s)
I changed my home screen since my post a few days ago. Here's the new one. Still using Nova launcher pro and zooper widget pro(different pack) . Obviously a new wallpaper too, 2k, that I think looks pretty sick on my gold edge.
Re: Post Pictures Of Your Home Screen(s)
Is that the one from XDA that you have to work some mojo to get it to go on right now? Or somewhere else? Link! :)
So sorry for the late post! This is a different theme that Samer Zayer made and submitted. This apk is a trial, but it's the file he submitted to the store. Since it's a trial, it resets after 5 minutes, but you can just disable the theme store and it'll stay. It's a really great theme! (No root necessary)
Anyone know of a place to get extremely hd wallpapers (other than zedge..)?
If you're into Material Design type wallpapers, you can't go wrong with Tapet. I use it and love it. Even purchased the Pro version.
https://forums.androidcentral.com/e...id=com.sharpregion.tapet&hl=en&token=2qy3GVAV
If you want more than just Material Design and geometric type wallpapers, I'd recommend Wally.
https://forums.androidcentral.com/e...?id=com.musenkishi.wally&hl=en&token=lO0hhXXL
Just a heads-up on HD Wallpapers ... if you simply use Google 'images' to search for "HD Phone Wallpapers" ... you will find a near endless supply of free wallpapers you can download and use. You can also refine your search for dark, abstract, nature, etc. (whatever you want) by doing something like "HD Abstract Phone Wallpapers".
That's how I find the vast majority of mine ... of course, I tend to edit them after finding them to be exactly what I want. If you have any photo-editing capabilities, you can crop, recolor, etc the image to better suit your needs as well.
The dark red theme that was posted on the XDA Dev forum.
My new homescreen
Using regular TouchWiz as on the S6 I have found to like much more than previous Samsung phones.
To the left I have a little sidebar which I made with Zooper Widget Pro using the Gel icon pack with the purpose of displaying my most used Widgets. I don't like having multiple pages with widgets but I do use them so I use an app called Popup Widget which allows you to create widgets as shortcuts instead. And I'm using one of the newest themes in the Samsung theme store.
What theme in the Samsung store is that?
Nevermind found it! But do you find that zooper drains your battery?
It does and it doesn't. I think it all depends on how you use Zooper. The times that I've used it for like clock, weather and other widgets that update every 30 minutes to an hour depending on the time frame you set for it update it does. But since I'm just using it this way to bring up my app widgets it's not draining battery at all.
New set up. Nova launcher, silhouette skin and zooper widget, flaterial skin. Lovin ittttt
I only have my time on my zooper widget and no drain. I've had one with time and date and no drain. If you're going to have weather and location on then it will definitely drain like any other widget. But for some reason compared to other widgets the basic stuff like time, date, etc, it seems to drain less. At least for me it does.
aimalee
